![]() | Home > General > Swapping a number plate |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
As far as I know, it can be without an MOT as long as it is on a SORN. The problem is that if you've let that lapse, then you need to get it taxed and for that you need an MOT.....
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
I wasn't aware you could do the removal without an MOT.... We have done some quite extensive work on customer cars for the sole purpose of removing the customers private plate... As recently as the last few months too...
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Craig, how many laps does a SORN have to do? |
Stupid darn iPad... That's what happens when I look on here from the other side of the world Ross...
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Or you can transfer onto a retention document - you pay the fee to transfer onto a vehicle but it is just on a retention document or at least you used to be able to |
The donor vehicle must have the following
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
So if it has neither an MOT or SORN, can you not just declare SORN and then transfer off the plate? Got - 2017 SDV8 Autobiography in Loire Blue
