![]() | Home > Technical (L322) > Help required in France, Restricted performance error msg |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Very sorry to hear you are having problems while away Mark, it sounds as though you are getting good service from the dealer thankfully. Hope it all turns out ok without too much expense. Agueroooooooooo. 93-20
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
An encouraging result, Mark. Worth getting them to replace the sensor anyway for peace of mind? John
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
If only the UK dealers were so accommodating....... |
Mactech Member Since: 27 Jun 2015 Location: Biddulph Posts: 126 ![]() ![]() ![]() |
I had the 'Restricted Performance' warning pop up spasmodically last week on my 4.4 TDV8.....but with no loss of performance.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Good stuff must admit I have found French garages remarkably good and fair for my tuppence worth I would go with Weegie and get it done over there it will probably work out cheaper and at least you know the fault is cured - either way good luck |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Looking good. |
Update:
You have PM. John
Thanks to Weegie my car is now booked into the Nantes dealership on Thursday at 08:30 to have the required work undertaken.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
depends if it says 'dpf full, refer to handbook' or 'dpf full see dealer'...the first can be sorted by a 20 minute drive at around 50mph to extinguish the warning triangle on the dash.. ... - .- -.
Hi Stan,
then the dealer it is Mark... |
The question is, can I drive it to the dealer? A journey of 40 miles |
