Home > Technical (L405) > TCM Re-Programming ??
andy2577
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Hi Guys
Asking on behalf of a friend who isn't a member on here.
He has a 2014 RR L405 and has developed some sort of an issue and as a result he changed the gearbox for a s/h one . The only problem is that the s/h box he has put in wont communicate to the car as the TCM cant recognise the vin as the box is from a donor vehicle.
Just wondering if there is anyone who can re-program the TCM to his vin ?
any feedback much appreciated and I will forward on your comments
cheers Thumbs Up 2002 - Blue L322 3.0 TD Vogue (Previous)
2006 - Black L322 4.4 V8 Vogue Autobiography (Previous)
2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present)
Post #396591 18th Jul 2016 11:55am
Dealer ? All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #396597 18th Jul 2016 12:09pm
andy2577
apparently when he spoke to his dealer the only advice they gave was (buy a new box) Rolling Eyes 2002 - Blue L322 3.0 TD Vogue (Previous)
Post #396598 18th Jul 2016 12:10pm
bear100
Speak to BAS (bell auto services) he and one or two others remap all land rovers and may be able to help! 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #396628 18th Jul 2016 4:52pm
GraemeS
Australia
Contact Davis Performance at Annandale or Graeme Cooper in Sydney. Also ZF in Blacktown should be able to transfer the original TCM data to the replacement box as they did that when rebuilding my D4's box.
The mechatronic unit from the original box could be swapped unless the old box had developed a problem with the valve body making that undesireable.
Post #396648 18th Jul 2016 7:11pm
Thumbs Up All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #396670 18th Jul 2016 8:51pm
andy2577
Cheers Guys
thanks very much for the replies, I will forward the information on
Post #397231 23rd Jul 2016 12:54am
Mikey
If it's on a 2014 car, is there any reason iwhy the gearbox fault is not covered under manufacturers warranty? Confused
Post #397242 23rd Jul 2016 6:25am
callumrr
2012 Range Rover Autobiography Black 5.0 SC V8 Java Black
Hi guy re gear box would need to be coded with vin write film for the sc hand box to work
Post #420662 1st Jan 2017 9:31pm
caymanblack
^^^This ,seems strange.
Post #420695 2nd Jan 2017 9:40am
callumrr
Yes dealer would say that as they wouldn't want to code a second hand box if any thing went wrong there or afterwards they would then be seen as liable, you can code it with SDD ONLINE. The reason why it doesn't work is due to the second hand box not having the current vin number stored by this not being saved in the gear box the gate way control module can't talk to the gear box
Thanks Callum
Post #420697 2nd Jan 2017 9:48am
callumrr
Only reason would be car was crashed damaged before which is common warranty becomes void, also if it's covered like 100k with over services due
Post #420699 2nd Jan 2017 9:50am
andy2577
gearbox was sorted in the end 2002 - Blue L322 3.0 TD Vogue (Previous)
Post #420775 2nd Jan 2017 4:51pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
would it interesting to know how the gearbox was sorted out in the end...? '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #426341 5th Feb 2017 3:56am
