![]() | Home > Technical (L405) > TCM Re-Programming ?? |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 ![]() ![]() ![]() |
Dealer ? All my spelling errorz are belong to me!
andy2577 Member Since: 04 Jun 2016 Location: Liverpool Posts: 64 ![]() ![]() ![]() |
apparently when he spoke to his dealer the only advice they gave was (buy a new box) |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Speak to BAS (bell auto services) he and one or two others remap all land rovers and may be able to help! 2010 defender utility
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Contact Davis Performance at Annandale or Graeme Cooper in Sydney. Also ZF in Blacktown should be able to transfer the original TCM data to the replacement box as they did that when rebuilding my D4's box.
Cheers Guys
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
If it's on a 2014 car, is there any reason iwhy the gearbox fault is not covered under manufacturers warranty? ![]() |
callumrr Member Since: 06 Nov 2015 Location: essex Posts: 3 ![]() ![]() |
Hi guy re gear box would need to be coded with vin write film for the sc hand box to work |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1156 ![]() ![]() ![]() |
^^^This ,seems strange. |
Yes dealer would say that as they wouldn't want to code a second hand box if any thing went wrong there or afterwards they would then be seen as liable, you can code it with SDD ONLINE. The reason why it doesn't work is due to the second hand box not having the current vin number stored by this not being saved in the gear box the gate way control module can't talk to the gear box
Only reason would be car was crashed damaged before which is common warranty becomes void, also if it's covered like 100k with over services due |
gearbox was sorted in the end 2002 - Blue L322 3.0 TD Vogue (Previous)
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 ![]() ![]() ![]() |
would it interesting to know how the gearbox was sorted out in the end...? '01 1.8i Freelander. Grey/ grey
