![]() | Home > Technical (L322) > Fault code P0401-20 |
Jones S13 Member Since: 16 Jul 2016 Location: birmingham Posts: 8 ![]() ![]() |
What code reader were you using? wording seems strange. I'm sure that code relates to EGR insufficient flow (because it is blanked) not so sure on the L322 but I know from experience on BMWs when blanking the EGR it needs to be 'written out' of the ecu. Or you can drill a small hole in the blanking plate to let a small amount of gas through so it can 'see' EGR flow. Personally I'd have it mapped. |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Hi Jones S13,
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
The egr on the td6 is vacuum operated. When you blank it off, blank /block the vacuum hose. Job done.
Thanks Wayne. |
Found leak in top hose that comes from intercooler steel pipe to inlet manifold.
I am sure someone on AULRO recently found a silicone substitute in Supercheap or Repco. Maybe ask there, I cant as I dont pay.
