Home > Technical (L322) > Fault code P0401-20
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Fault code P0401-20
Have a new fault with my beast.
Its on an 03 TD6.
P0401-20 Extended fault path exhaust recirculation governor deviation--negative deviation.
Have got the EGR blanking kit in it.
How to I go about fixing this issue?
Car has been running very good.
Thanks
Post #396444 17th Jul 2016 5:47am
Jones S13
What code reader were you using? wording seems strange. I'm sure that code relates to EGR insufficient flow (because it is blanked) not so sure on the L322 but I know from experience on BMWs when blanking the EGR it needs to be 'written out' of the ecu. Or you can drill a small hole in the blanking plate to let a small amount of gas through so it can 'see' EGR flow. Personally I'd have it mapped.
Post #396540 17th Jul 2016 10:05pm
littlecub
Hi Jones S13,
Its was taken from iid tool.
Checked the faults on Saturday and it came up,cleared it all then checked again yesterday and the same one came up again.
Hence the question.
Thanks for the tip on drilling small hole.
cheers
Post #396558 18th Jul 2016 7:09am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The egr on the td6 is vacuum operated. When you blank it off, blank /block the vacuum hose. Job done.
Check your vacuum hose has not sprung a leak. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #396601 18th Jul 2016 1:44pm
littlecub
Thanks Wayne.
Post #396681 18th Jul 2016 10:34pm
littlecub
Found leak in top hose that comes from intercooler steel pipe to inlet manifold.
Rang supplier and they only sell the complete unit, from bottom of intercooler up.
Any know if you can just get the top hose?
Thanks
p.s. disregard the very small pipe that lays on top of it.
Post #396690 19th Jul 2016 4:11am
wayneg
I am sure someone on AULRO recently found a silicone substitute in Supercheap or Repco. Maybe ask there, I cant as I dont pay.
Try a BMW dealer, part number could be 11617799389 ??
This hose on ebay looks correct? Not a bad price with free ship. http://www.ebay.com.au/itm/BMW-E38-E39-E46...SwNuxXY8oi 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #396691 19th Jul 2016 4:30am
