Home > Maintenance & Mods (L322) > Heated / cooled seats question.
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Anyone know how the heating / cooling system works for the front seats? (MY2011).
Reason I ask is that my driver's seat cools really nicely, but doesn't seem to heat at all. Passenger side works fine both heating and cooling.
Checked fuses. All fine.
Is there a heating 'element' that could have failed just on the driver's side? Confused Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #396016 14th Jul 2016 10:52am
Zeppfish
apparently they use a thing called a peliter module which has either a heating effect, or a cooling effect depending on which way an electrical current is passed through them. Have a read up on
https://en.wikipedia.org/wiki/Thermoelectric_cooling
I believe the FF seat modules are coupled with a fan that then blows the hot or cold air into the back, or the base of the seat. Thy have a filter that is re-placeable as well.. Have a look in The WIKI. This is where I read about it all.
could be an iffy connection somewhere! 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #396057 14th Jul 2016 2:35pm
I have just fixed this problem but I can't garentee yours is the same , it was a split hose in the peltier cell in the back rest . When in heating mode the seats ECU's needs a temperature return which it can't get due to the split letting the air out but in cooling it goes closed loop so just keeps working , or some guff like that 😉
So what to do ? Well your seat has to come out and be checked over for possible damaged cells or broken wires . Get some help though ,they are heavy and I damaged my piano black trim💩 2008 MY Supercharged
Post #396141 15th Jul 2016 7:10am
