![]() | Home > In Car Electronics (L322) > Bluetooth music streaming in any FF |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Well BUT if you have an USB connect already in your car - do you still need that 3,5 male connection ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
It's an AUXiliary in plug, usually 3.5mm jack plug, a lot of the late ones have it as standard, I think you can get a kit to fit yours... Pete
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Received ours yesterday and works ok.............. I say ok because its plugged into the aux at the rear and it works ok for music from the phone but then we cannot use the cars phone system.
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
If you have the iPod connection in your centre console and an OEM LR iPod lead, this is quite an elegant solution (although not the cheapest).
Thank you jfb1977 - i have just ordered one over Amazon Germany - i hope it works on our Jaguar - anyway they refund if it does not work |
Should work with any car that has an OEM iPod connection that uses the 30 pin connector I believe.
I will get it next Tuesday and report back |
Is your Jag cable USB one end, Apple 30 pin connector the other?
Just checked the owners handbook online...
Perfect. If you've got an OEM iPod lead with the 30 pin plug on the other end you should be golden. |
I will - thanks mate ! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
that is the same thing as the tune2air and will work splendidly. There is nothing that can't be fixed with a hammer😜😜
stwid Member Since: 03 Jun 2016 Location: Isle of Wight Posts: 31 ![]() ![]() ![]() |
Hi, I have a 2004 with the earlier non touch screen. Is it possible to fit a aux lead or the 30 pin Apple connection.
tiddles1991 Member Since: 10 Jul 2016 Location: Cleethorpes Posts: 32 ![]() ![]() ![]() |
I'm the same stwid, an easy option would be to put a aux cassette in the tape player bit.
