![]() | Home > Maintenance & Mods (L322) > battery flat and super locked |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
@ babknob
That is a worry - security wise..... |
Adriansj Member Since: 22 Jun 2021 Location: Swindon Posts: 8 ![]() ![]() ![]() |
How, Can you explain in more detail please? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, Not sure about white capped socket as I have a 13 pin tow kit, but you can charge the battery via the unswitched +12v & Gound pins of the towing electrics.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
Check the forum shop, they sell a range of plug in adapters .
Hi,
I could not find anything on the shop so what if I just get an 8 pin from a caravan shop and strip the wires and connect to my battery charger but just use the lower 6v option to get enough juice into the battery for a few hours. If this fails I'll call AA or smash a window to pop the bonnet. Anyone know the layout of the 8 pin adaptor?
They should be 7 pin, here's a generic diagram from the internet.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
That wont do it, you need 13.8v and above to charge the 12v battery. Use pin 3 (-ve) and pin 4 (+ve) BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
As is probably in one of the replies, jack the Right hand front of the car up, connect charger to the starter motor positive terminal and a good chassis earth and you are good to go. |
Cant really understand that diagram but I'm assuming pin 4 for the live and no idea about the negative? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Earth = negative
Ok so I have live to pin 4 and negative to pin 3 which seems correct. |
correct BMW i3 Electric Car
