Home > In Car Electronics (L322) > :-( broken my instrument cluster |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I wouldn't drive it without the cluster as the unit stores the odometer reading which gets cross checked against other units in the car. If they differ then the car starts throwing errors in that regard as well.
2nd Jul 2016 11:22am |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
I recently broke one dial, (temp gauge), whilst trying to repair my cluster (and not following the guides ). So I used this company:
2nd Jul 2016 11:47am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Great guys thanks sorry if that sounded a bit angry it was me angry with myself calmed down a bit now will call rudi and cartronix - driving with cluster in for now although dash loose and using Gps speedo... |
2nd Jul 2016 5:24pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Have a search on here or the web, there is a way, to cycle all the dials through a test. That saying, all the needles, will 'Rev up' through a cycle, and return. This might reset the troublesome needle(s).
3rd Jul 2016 8:36am |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 |
Hi all, i am looking at a RR Vogue,here is south africa. has the TD 6 engine. on the clock is has 222000kms.
4th Jul 2016 1:10pm |
yes it repairable here (UK) via mail order, for about £100. ie your original unit is returned fixed. the DIY method, is very tricky to do correct, first time.
4th Jul 2016 2:00pm |
Thank you. i will look at it.
4th Jul 2016 2:07pm |
i should add that, simply obtaining a secondhand unit, with better pixels, is not straightforward, and the mileage wont be accurate, and could be reading way over the actual cars' mileage. and is irreversable. (i believe)
4th Jul 2016 2:30pm |
Wow, that is most reasonable.
4th Jul 2016 2:38pm |
Www.bmwpixelfix.co.uk they can do you a white led conversion as well |
5th Jul 2016 8:57pm |
Its back he managed to fix one and replace 3 all good now - also did the white conversion which looks pretty good and now i have good pixels
8th Jul 2016 12:27pm |
Oohh I like that!! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
8th Jul 2016 3:26pm |
its quite reasonable - i think its £80 as a mod on its own or £50 with a pixel fix or servo change - seemed rude not to! |
8th Jul 2016 3:31pm |
That's a good price, I paid £99 for pixel repair + £45 for temp gauge repair and I thought that was good! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
8th Jul 2016 3:36pm |
