Home > Maintenance & Mods (L322) > SC 5.0 Brembo Brake Bleeding
Long story short: Brembo brakes are harder to bleed.
Car was serviced in November 2015 and main Dealer noted on the VHC that brakes felt spongy, requires investigation.
I had the brake fluid changed in march 2016 at a local garage (as it was due) - made no difference and if anything got worse.
Car into an Indy today (LR Specialist) as brake pedal almost to the floor and it was damned scary.
Phone call to say car is done, took over 3 hours to fully bleed the system, the Brembos have 2 bleed nipples and it sounds like it's a tricky job to get all the air out. They commented that maybe the local garage who did the brake fluid got air in and didn't know how to bleed the system properly.
Pedal now firm as it should be . Discovery 4 HSE
Post #395052 8th Jul 2016 3:21pm
Just realised this is in the wrong section:
As I am no longer a Mod I can't move it, can someone else attend to this. Discovery 4 HSE
Post #395053 8th Jul 2016 3:22pm
done Thumbs Up ... - .- -.
Post #395054 8th Jul 2016 3:23pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Sorry to drag up a 7 year old post buuuuuut
I've just changed pads and discs on the front of my Fatty with the Brembo 6 pots. I had to take the calipers off both sides for various pin related reasons and, although I clamped the hoses, inevitably I need to bleed the brakes.
My question is, as there are 2 bleed nipples, is there a specific method too get these brakes bled succesfully or is it the same as all oother cars but 2 nipples on the fronts so double thee bleeding?
Thanks for your help Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658476 4th Mar 2023 9:03pm
Gremlin500
Hi Goldstar,
Yes, I can help on this.
Last year I upgraded the brakes on my TDV6 to the larger diameter discs front & rear and added the front 6-pot Brembos.
(I am a specialist industrial brakes engineer for the past 30 years, so the mechanical stuff was quite straightforward).
However the bleeding is not so easy with these brakes! -you have to initially bleed the brakes in the conventional way to get rid of most of the air, starting with the calipers furthest from the reservoir, but then it requires the intervention of a diagnostic tool to run the ABS pump (engine running) to purge the remainder of the system. At the time I did not have the iCarSoft LR V3 tool, so had to take it to the local Indy, and even with the latest JLR PathFinder equipment, it took them 3 attempts to bleed the system correctly. The brakes are night and day different afterwards. Air can remain trapped in the ABS pump and result in a frustratingly spongy/scary pedal. Shocked
Unless you have the specialist equipment, I suggest going to a land rover indy or dealer.
Craig or Phoenix may offer more knowledgable advice on this subject Bow down Bow down Bow down -the industrial stuff I deal with has no ABS and I know nothing about such systems unfortunately. Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #658482 4th Mar 2023 11:57pm
WDRR
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Good shout Gremlin500🤞 Bow down Willie
2008 TDV8 Santorini Black
Post #658485 5th Mar 2023 12:33am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Brenbo Brakes 6 pots.
Glad Goldstar raised this.
Wonder if the use of one of the pressure bottle kits on sale these days would take care of the problem, anyone?
Dave
Post #658497 5th Mar 2023 8:51am
Gremlin500
@Nylands,
I used such a kit, it didn’t do the job unfortunately. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #658499 5th Mar 2023 8:56am
Goldstar
Thanks Gremlin. I should have mentioned that I have an IID - does that do the job of a proper bleed does anyone know? Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658502 5th Mar 2023 9:13am
JayGee
AFAIK the GAP has an ABS purge function but not sure if this is the same as a full brake bleed function. The main issue for most will also be the fact that the bleed nipples will be galvanicaly seized in the calliper body so bleeding the brakes will be impossible anyway. 2012 TDV8 Vogue (L322)
Post #658506 5th Mar 2023 9:18am
Goldstar
You’re not helping my optimism Shocked Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658515 5th Mar 2023 10:04am
I can't see that changing the front callipers needs a diagnostic tool, I find gravity bleeding works well... Open the bleed nipples, keep the reservoir filled up and wait till it drips out cleanly with no bubbles... always worked for me and this way prevents the system sucking in air..... Thumbs Up
From the manual,
If any components upstream of the Hydraulic Control Unit (HCU),
including the HCU itself are replaced, the brake system must be bled
using Land Rover approved diagnostic equipment. This will ensure
that all air is expelled from the new component(s).
Bleeding of the complete brake system must be carried out using
Land Rover approved diagnostic equipment. Where only the primary
or secondary brake circuits have been disturbed in isolation, it should
only be necessary to bleed that circuit. Partial bleeding of the
hydraulic system is only permissible if a brake tube or hose has been
disconnected with only minimal loss of fluid.
 Pete
Post #658516 5th Mar 2023 10:33am
Goldstar
Very helpful thank you. I’ll try bleeding them and see what happens. Cheers Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658517 5th Mar 2023 10:36am
cass
Yes the IID does do a bleed sequence - it even tell you which sequence to bleed the calipers, I can't remember the details of it but I did have to do it twice - I think it was just my inability to follow instructions.
Post #658518 5th Mar 2023 10:41am
JayGee
Gravity bleeding isn't very good with air trapped in the lines as it will simply rise up against the flow. Better than trying to suck fluid out which is the worst method. Pressure bleeding is best IME but you need a good unit that can provide the right amount of pressure and they are not cheap. 2012 TDV8 Vogue (L322)
Post #658523 5th Mar 2023 11:07am
