Home > In Car Electronics (L322) > :-( broken my instrument cluster
Danwilderspin
So I followed the guides on here on how to fix the lcd panel on on the cluster I started about 6pm and finished at midnight. I followed the guide pretty much step for step however I stupidly put the unit face down on the dial while working on the back , now I have a panel working like new and in a stroke of horrible bad luck I've wasted 6 hours and made the problem 10 times worse as the steppers don't return now - what's the best way to fix or best person to fix in the uk Sad can you drive without the cluster temporarily?[/i]
Post #394114 2nd Jul 2016 8:30am
fisha
I wouldn't drive it without the cluster as the unit stores the odometer reading which gets cross checked against other units in the car. If they differ then the car starts throwing errors in that regard as well.
Can't help you with the cluster though I'm afraid. Do the needles move at all ? V8 or else ...
Post #394137 2nd Jul 2016 11:22am
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I recently broke one dial, (temp gauge), whilst trying to repair my cluster (and not following the guides Embarassed ). So I used this company:
http://www.cartronix.co.uk/
repaired the same day as received and back to me the next day. Give them a call, I found them very helpful and not overly expensive! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #394140 2nd Jul 2016 11:47am
Danwilderspin
Great guys thanks sorry if that sounded a bit angry it was me angry with myself calmed down a bit now will call rudi and cartronix - driving with cluster in for now although dash loose and using Gps speedo...
Post #394161 2nd Jul 2016 5:24pm
johnboyairey
Have a search on here or the web, there is a way, to cycle all the dials through a test. That saying, all the needles, will 'Rev up' through a cycle, and return. This might reset the troublesome needle(s).
I seem to remember having to do this, because when I did mine a few years ago, the fuel gauge was put back on wrong. I seem to remember removing that needle, and not being able to work out where it should have been placed, and the needle didn't work, but doing the test, it showed tat they did all move, and where it should sit. It's only a few presses of the buttons on the cluster.
Like here...
Post #394229 3rd Jul 2016 8:36am
frikkadel
South Africa
Hi all, i am looking at a RR Vogue,here is south africa. has the TD 6 engine. on the clock is has 222000kms.
A lot of the small led displays are not working, so a portion of the number can be read.
i Hear that this can be repaired.
is this so?
Post #394378 4th Jul 2016 1:10pm
johnboyairey
yes it repairable here (UK) via mail order, for about £100. ie your original unit is returned fixed. the DIY method, is very tricky to do correct, first time.
Also, being it is possibly, the early 2002-2005 model in question, you can swap out the whole head unit, for a much more modern android all in one touchscreen/dvd/cd/radio/GPS/bluetooth/phone etc, with added extras like DAB and TV. these units are about £350, and there is a long write up, search 'android head unit' or similar on here.
it is DIY ready...if you are useful with cars/tools. and soldering.
Post #394390 4th Jul 2016 2:00pm
frikkadel
South Africa
Thank you. i will look at it.
sounds very good.
Post #394392 4th Jul 2016 2:07pm
johnboyairey
i should add that, simply obtaining a secondhand unit, with better pixels, is not straightforward, and the mileage wont be accurate, and could be reading way over the actual cars' mileage. and is irreversable. (i believe)
so repair of original is the best option
example here. in no way a recommendation. http://www.clusterrepairsuk.co.uk/featured...xel-repair
Post #394398 4th Jul 2016 2:30pm
frikkadel
South Africa
Wow, that is most reasonable.
I will have it sent to them, when i purchase later in the week
Post #394403 4th Jul 2016 2:38pm
Danwilderspin
Www.bmwpixelfix.co.uk they can do you a white led conversion as well
Post #394686 5th Jul 2016 8:57pm
Danwilderspin
Its back he managed to fix one and replace 3 all good now - also did the white conversion which looks pretty good and now i have good pixels Smile
Post #395030 8th Jul 2016 12:27pm
Lenb
Oohh I like that!! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #395055 8th Jul 2016 3:26pm
Danwilderspin
its quite reasonable - i think its £80 as a mod on its own or £50 with a pixel fix or servo change - seemed rude not to!
Post #395057 8th Jul 2016 3:31pm
Lenb
That's a good price, I paid £99 for pixel repair + £45 for temp gauge repair and I thought that was good! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #395058 8th Jul 2016 3:36pm
