Home > Technical (L322) > Code reading issues
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
Code reading issues
Hi can anyone help ? I have an airbag light on so took it to my local Indy to find the problem. That's all sorted now, however while it was there I asked him to check for any error codes on the engine. He was using a snap on solus with the latest software but it would not let him access the engine. Also noticed that the engine management light does not illuminate and go off when the ignition is turned on. He could access all other functions apart from the engine. Any ideas why this is happening ?
Post #394076 1st Jul 2016 9:53pm
Road Stone
Check the fuse?
You probably need to plug it into a recognised LR diagnostic tool to confirm there is an issue. May be someone lives near you with an 11D /Nanocom/Hawkeye you could ask.
Cheers, Jerry THIS WRECKAGE
Post #394109 2nd Jul 2016 7:56am
