![]() | Home > Camping, Caravanning and Holidays > Duplex tunnel |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Off in a couple of weeks to South of France was thinking of going A26 but fed up being held up at Lyon anyone any experience of going via Paris and using the Duplex tunnel think it has a 2m height restriction are we ok at that margin?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
the FF is just a few cm' s lower than that so if your van is higher than the FF then it wont go under.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
The telepéage gates (using a transponder) on autoroutes are generally 2m and I use them without problem.
No will be taking the RR just had all the rear arms replaced (after a no faults found mot pass ) but thought it was just a tad loose so replaced the lot and the shocks and front arms drives like new so she will go to south again |
Here Stan why did you think I would take a van instead of the RR haha |
Well good cure for that Stan is to make sure your alcohol levels are sufficient enjoy the break
We are down in Cap D'Agde for a few days then round the coast to Frejus then back up north to my sisters in Hesdin Pas de Calais so a good run for fattie how long are you over there for ? |
Will you be keeping your clothes on at Agde? |
sounds like a full on trip Sandy....we are travelling to Reims tomorrow and then back to the UK on tuesday... ... - .- -.
Wouldn't want to scare the natives haha we are down looking at property in Bezier time to get away from the rain or at least in next 3 yrs |
Well enjoy Stan sure you will have a brilliant time ![]() ![]() |
Thought I would update trip done found a couple of houses to go back and look at |
