Home > Maintenance & Mods (L322) > tips for winter |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
thought i might start a thread for members tips to help prevent winter woes with the FFRR..
24th Nov 2010 12:30pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Keep a warm blanket in the car. Handy if you have a problem. |
24th Nov 2010 12:42pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
or get lucky |
24th Nov 2010 12:43pm |
Did that last year and it worked all winter! Original problem was the door stuck open or closed due to frost. WD40 immediate cure best applied with the straw direct into key slot and then onto the mechanism. |
24th Nov 2010 12:47pm |
Next thing you need is a set of Vredestein Wintrac 4Xtreme tyres for massive grip in the snow and they look great too....(www.camskill.co.uk) |
24th Nov 2010 12:48pm |
tip confirmed... ... - .- -. Y. O. L. O. . |
tip from happymadison1978.
24th Nov 2010 12:50pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
If there is a heavy frost, then run a credit card along the top edge of the door before you open it, as sometimes the rubber seal will weld itself to the roof of the Range. If you don't do this, then the seal can stick to the roof and pull itself away from the door as you open it, which will permanently damage the seal. |
24th Nov 2010 12:54pm |
WD40 - worst thing you can put in a car lock.
24th Nov 2010 12:58pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Mobile phone.... |
24th Nov 2010 1:03pm |
any alternatives dan? ... - .- -. Y. O. L. O. . |
24th Nov 2010 1:08pm |
I used to use vasaline on door seals, then read somewhere that wasn't a good idea.... |
24th Nov 2010 1:12pm |
Thanks for the tip re WD40 Dan I guess its just a quick fix if you really cannot shut the door a position I was faced with! |
24th Nov 2010 1:18pm |
Graphite or Teflon powder for lube.
24th Nov 2010 1:52pm |
