![]() | Home > Maintenance & Mods (L322) > tips for winter |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
thought i might start a thread for members tips to help prevent winter woes with the FFRR..
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Keep a warm blanket in the car. Handy if you have a problem. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
or get lucky |
Did that last year and it worked all winter! Original problem was the door stuck open or closed due to frost. WD40 immediate cure best applied with the straw direct into key slot and then onto the mechanism. ![]() |
Next thing you need is a set of Vredestein Wintrac 4Xtreme tyres for massive grip in the snow and they look great too....(www.camskill.co.uk) |
tip confirmed... ![]() Y. O. L. O. . |
tip from happymadison1978.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
If there is a heavy frost, then run a credit card along the top edge of the door before you open it, as sometimes the rubber seal will weld itself to the roof of the Range. If you don't do this, then the seal can stick to the roof and pull itself away from the door as you open it, which will permanently damage the seal. |
WD40 - worst thing you can put in a car lock.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Mobile phone.... |
any alternatives dan? ... - .- -. Y. O. L. O. . |
I used to use vasaline on door seals, then read somewhere that wasn't a good idea.... |
Thanks for the tip re WD40 Dan I guess its just a quick fix if you really cannot shut the door a position I was faced with! |
Graphite or Teflon powder for lube.
