Home > Maintenance & Mods (L322) > Fitting New Osram DRLs |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
sub'd 2014 FF Autobiography 5.0 SC
16th Oct 2015 2:54pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35381 |
i'm curious to know why you have dismantled the whole front to fit some drls... ... - .- -.
16th Oct 2015 5:30pm |
^^^ same. I'm thinking he has some sort of stealth lamps or is doing some wizardry that i definitely want to see. 2014 FF Autobiography 5.0 SC
16th Oct 2015 5:56pm |
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 |
Only for fun! Today I prepared the harness with thermo sleeve, sealing and tucked routing...
Right connector: Green wire to Pin 8
Red wire to battery
Bumper connector: Black and Yellow wires to Fog Lights pins
17th Oct 2015 12:06am |
Left connector: Grey, white and blue wires
17th Oct 2015 12:16am |
I want to see the actual lights 2014 FF Autobiography 5.0 SC
17th Oct 2015 1:33am |
Osramīs need to dremeling the support to fit, very easy.
18th Oct 2015 12:21am |
I added the new bezels...
18th Oct 2015 12:24am |
DRLs
18th Oct 2015 12:31am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
They are VERY good lights arnt they |
18th Oct 2015 12:33am |
Yes, very good!!
18th Oct 2015 12:38am |
have you wired the cornering function sir? |
18th Oct 2015 12:43am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1776 |
I was looking forward to seeing these fitted. They suit the car very, very well
18th Oct 2015 4:53am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8289 |
Very nice, you have done a very thorough job, that rusty seam you cleaned off will re rust unless you have put some antirust treatment inside the box section to get into the seam, the rust is from the unpainted edges that were welded together... Pete
18th Oct 2015 8:44am |
