Home > In Car Electronics (L322) > Reverse cam retrofit problem
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Hi guys,
Just installed a reverse camera in my 2004.. did follow the wiki guide http://www.fullfatrr.com/forum/topic24647.html
The camera works fine but the relay is clicking when in reverse as if the reverselights isnt powerful enough to drive the relay.
Anyone got any ideas how to solve the problem? Ofc i want the relay coil signal to be taken from the reverselights so when i put it in reverse i get the camera on the display.. L322 Vogue 2003
Post #391807 15th Jun 2016 7:31pm
calletso
2002 Range Rover Vogue 4.4 V8 Giverny Green
Have you checked you have a good earth? Maybe try with another relay? The reverse light feed should be enough to switch the relay?
Post #391825 15th Jun 2016 10:09pm
Starberg
Pretty sure it has something with the reverselight-feed to do because when i connect the relay directly to the + on the battery the relay coil pulls and is scilent Big Cry L322 Vogue 2003
Post #391831 16th Jun 2016 4:24am
