Home > Maintenance & Mods (L322) > exhaust leak |
SNR Member Since: 16 Mar 2016 Location: Northen Michigan Posts: 15 |
You could try Loctite or maybe some stage 8 fasteners.
11th Jun 2016 3:01am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
New one on me! Try new fixings??? |
11th Jun 2016 8:09am |
Olly-Ibiza Member Since: 08 Jun 2016 Location: chester Posts: 49 |
If exhaust bolts nuts or studs have been used it's always best to replace them with new |
11th Jun 2016 8:22am |
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 |
Thanks everyone, I seen that looking at Jaguar parts exhaust manifold bolts. They come new with a thread lock sealant on them and no lock washers etc. Never seen that before, I'm old I guess 😩. Good news, know they're not seized. Guess will pick up some lock tite, thanks again for the help. |
11th Jun 2016 1:24pm |
seems like loctite 2620 is the product to use. |
11th Jun 2016 2:06pm |
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 |
Question regarding this:
15th Jul 2016 5:58am |
it is way way easier than it looks, especially if you have access to a hoist. 3/8 drive socket, u-joint, long extension and think it wall like a 13mm. you can get all but two easily from below, front drivers side one from above after popping off air filter box and finally the front passenger side one I couldn't get to because of alternator heat shield in way. It appears I must remove the alternator to get to this bolt so I would arrange to have the alternator rebuilt at the same time ( always like rebuilt over new).
19th Jul 2016 3:01pm |
