Home > Maintenance & Mods (L322) > exhaust leak
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
exhaust leak
Maybe someone has felt with this before, on my 2007 4.2sc the exhaust manifold bolts keep coming loose. I can tighten them and have a day of silence then by the end of the next day the leak is back just as bad and the bolts are loose again. I have tried tightening when hot and when cold. any suggestions? Thanks
Post #391162 11th Jun 2016 2:46am
SNR
United States 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
You could try Loctite or maybe some stage 8 fasteners.
http://www.stage8.com/imports.html
Post #391163 11th Jun 2016 4:01am
New one on me! Try new fixings???
Post #391178 11th Jun 2016 9:09am
Olly-Ibiza
If exhaust bolts nuts or studs have been used it's always best to replace them with new
Post #391182 11th Jun 2016 9:22am
vitola231
Thanks everyone, I seen that looking at Jaguar parts exhaust manifold bolts. They come new with a thread lock sealant on them and no lock washers etc. Never seen that before, I'm old I guess 😩. Good news, know they're not seized. Guess will pick up some lock tite, thanks again for the help.
Post #391234 11th Jun 2016 2:24pm
vitola231
seems like loctite 2620 is the product to use.
Post #391238 11th Jun 2016 3:06pm
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
Question regarding this:
How can you reach al the bolts of the exhaust header?
I can't hardly imagine reaching the bolts, removing the studs is not doable? MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #396140 15th Jul 2016 6:58am
vitola231
it is way way easier than it looks, especially if you have access to a hoist. 3/8 drive socket, u-joint, long extension and think it wall like a 13mm. you can get all but two easily from below, front drivers side one from above after popping off air filter box and finally the front passenger side one I couldn't get to because of alternator heat shield in way. It appears I must remove the alternator to get to this bolt so I would arrange to have the alternator rebuilt at the same time ( always like rebuilt over new).
Problem is with a universal joint on socket you can't really tell how much torque is going into turning bolt apposed to binding the u-joint. Wish they made one geared like a Tatra drive train.
Post #396751 19th Jul 2016 4:01pm
