Home > Technical (L322) > Help Needed with A Friday Afternoon Range Rover |
fatbob Member Since: 16 Aug 2015 Location: Munich Posts: 19 |
Hi All,
6th Jun 2016 5:21pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Probably won't help you, but there was a guy on a forum that had a Jaguar X type, same problem in the end he had to get a refund for the car as over 6 months of going to and from the garage they just couldn't fix it! |
6th Jun 2016 6:30pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Have you or the dealer considered changing the DPF? |
6th Jun 2016 7:10pm |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Just a thought. There has been a lot of discussion about using 2 stroke oil as a fuel additive. Apparently it burns hotter than diesel and therefore helps the DPF among other benefits. Have a root round t'interweb and see what you think. |
6th Jun 2016 7:51pm |
Hi All,
7th Jun 2016 6:58am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
I can't help I'm afraid, but this sort of thing really makes my blood boil. The dealer has sold you an expensive car that doesn't work properly, why the hell aren't they bending over backwards to sort it out for you? This is, purely and simply, is crap customer service. Whoever they are or wherever they are they do not deserve to have a business. Drives:
7th Jun 2016 7:04am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I didn't know you had the saying "Friday afternoon job" in Germany fatbob
7th Jun 2016 7:11am |
If the DPF get past a certain stage it will not self clean and replacement or an off car specialist clean are the only options. As the dealer is doing no.2 hopefully this will fix it. No choice with these cars but to apply a bit of motorway throttle on a regular basis. |
7th Jun 2016 7:22am |
Hi All,
7th Jun 2016 8:41am |
^ Reason its going straight to RED is that it is Fubared already... |
7th Jun 2016 9:27am |
