Home > LPG > Engine management light after failed start
smiler289
Hi, well after solving why our car wouldn't start, loose negative battery cable, it's thrown up the eml today. We drove for about half hour on lpg on our 03 fine, stopped for 10 minutes then went to restart engine and got nothing, nothing at all, even all lights stayed on dash, no engine turn over or relay clicking etc. Tried it again and started perfectly. Drove off then eml came up.
I am wondering if it is to do with the lpg service we had done last week, they cleaned the exchanger but everything else was fine.
Not had the ecu read yet.
Any suggestions? I visually inspected the hoses at top rear of engine and they seamed fine, but soft maybe but don't know how hard they supposed to be? Couldn't find any cracks etc.
Post #389752 1st Jun 2016 7:48pm
smiler289
Update. Eml turned off today after car was run just on petrol, will see what happens with running on petrol for a few more days then try lpg.
Post #389906 2nd Jun 2016 8:14pm
You won't come to any conclusions until you get the codes read... could be anything from a failing lambda sensor to a collapsed cat, may or maynot have anything to do with the LPG...
If it is ONLY happening on LPG then it hasn't been set up correctly and is probably running rich and over-fueling... lazy or inexperienced LPG tuners will use a base map and not tune the car individually with respect to STFT... this usually means running rich and setting off lambda faults...
I have noticed in the past that a lambda will fail on LPG before it fails on petrol so that may also be the case, but it's rare.... Thumbs Up Thumbs Up Pete
Post #389921 2nd Jun 2016 9:24pm
smiler289
Will the error code still be able to get read if the eml has gone out?
Post #389926 2nd Jun 2016 9:47pm
If the reader is clever enough, yes... Thumbs Up Pete
Post #389931 2nd Jun 2016 10:13pm
