Home > Maintenance & Mods (L322) > Suspension height for 22" wheels
Wagon mark
2006 Range Rover Vogue SE Td6 Santorini Black
Does anyone no what's the best height to set suspension at with gap iid tool want to lower it a little cheers
Post #389285 30th May 2016 6:50am
Will vary from tyre to tyre...
Just try it and see, check it doesn't hit on full lock and over speed bumps...
The lower you go the worse the ride will be.... Thumbs Up Pete
Post #389319 30th May 2016 11:39am
Check the small print on your insurance cover first... Most will see “lowered suspension” as a performance modification and either charge more premium or in extreme cases, use it as a reason to void your cover!
Post #389338 30th May 2016 12:45pm
betonklinker
Netherlands 2004 Range Rover Vogue Td6 Bonatti Grey
This is mine 'normal' height whit 22"
 I use Google translate, Sorry for my bad English...
Full Vogue Td6, new Gearbox, 22 inch Stormers, HSE, Cream leather
Post #389402 30th May 2016 5:41pm
