Home > Technical (L322) > trans fail prog mode |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Probably related to the battery. mine did this when the battery was old. With luck a decent battery should fix the problem unless there is an underlying problem causing your battery to be low (as opposed to just an old battery and not enough use to keep fully charged).
26th May 2016 7:41am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
As above, check the battery voltage level. For a fully charged battery in good health it should be reading around 12.6V. With the engine running and alternator working correctly it should read over 13.5V. Anything less could be a problem.
26th May 2016 7:54am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Once started turning the steering wheel from lock to lock clears the warning lights. |
26th May 2016 12:05pm |
Yorkie Member Since: 13 Mar 2016 Location: Shropshire Posts: 4 |
Many thanks for your replies, new battery on order now and the old one on charge overnight.
26th May 2016 5:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
Welcome..
26th May 2016 7:31pm |
many thanks for the link and help.. battery is retaining no charge at all so I've come to the conclusion the alternator needs replacing too.
26th May 2016 9:57pm |
