![]() | Home > Maintenance & Mods (L322) > Advice: Swollen nut stuck on socket |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
So, I went to remove the alloys from the Discovery 3 today and found that some of the nuts have the dreaded swollen issue under the caps..
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
I bought an aldis air wrench took it back was pants tbh no guts bought a snap on one and works great hope you get your nuts sorted !!! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Screw the wheel nut back on the car, then wiggle the socket up and down (with a long extension connected to the socket) then when you’ve removed the socket remove the wheel nut using a 23mm socket |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Aldi's air impact wrenches are pants straight ot of the box |
Thanks chaps |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 ![]() ![]() ![]() |
The other thing that helps performance is to use high flow fittings such as PCL XF or euro fittings as opposed to standard and use 10mm tube. |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Personally, I like air and have a CP7749 - at 980Nm, it takes the most stubborn bolts out with ease (but you do need the air too; I have a pair of 2.5hp compressors that I can link together). Cordless ones are certainly growing in popularity though, and Makita, Snap-On and Milwaukee ones have all had favourable reviews on the D3 forum. |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
I get mine out by putting the socket in a vice then use a punch to come in from behind through where the ratchet goes just make sure to try and hit around the edges otherwise you go straight through the nut L322 2008 vogue
Why do you ask that? Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
They break, causing the outer part to spin freely and leaving you even more in the |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
I've used an aldi Impact wrench for the last few years with no bother , it's the hose that's the problem you need a 10mm one as a 6mm one can't maintain pressure at the gun . |
