![]() | Home > Technical (L322) > '02 L322 4.4 L V8 Coolant issues/possible head gasket/HELP! |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
We've done some long journeys up north and Devon |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Cool, at least if mine have gone then it may be worth replacing them.. |
I did find this along the way....
Thank you for that, my problem was initially low oil pressure when the engine was hot but the temp never went past the middle of the gauge.
How did you get on Andy? |
howdy, i ordered a compression tester and leak down tester off ebay, now i admit that the compression tester was £15 but they had sold thousands so I thought i would be ok.
Good to hear.
I wrote a reply and it disappeared but thank you for that, powerflushing a transmission can move a lot of clutch debris into the valve body and transmission so can cause problems so could be similar issue. The internals of my engine were coated with a goldey orange deposit so maybe that is what I am seeing.
