![]() | Home > Technical (L322) > '02 L322 4.4 L V8 Coolant issues/possible head gasket/HELP! |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
* Mr Spock |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Of course it's possible they're right. But...
I've always been a fan of Mr Spock |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Bit of a resurrection this but wondering how the Op got on.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Fingers crossed for you buddy..worse case scenario it is the head gasket does a repair guarantee a fix? I presume you will do it yourself self as you seem pretty clued up..really hope it's not..keep us posted |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
one thing maybe to check easily, i did it on mine and it was faulty, the auxilliary water pump. yes, there is (on my 2002 v |
Thank you, I don't know if i would have the enthusiasm to remove the heads as there is no guarantee that replacing the head gaskets would fix it as the block could be damaged also but it would make sense that when the top hose went the engine would immediately lose all it's water and it might take a while for the level to drop and initiate the low coolant warning if the stat was closed. I have spent thousands upon thousands on this car so i am running out of the will to live !!
That is a good shout as on the meeknet site it says to bleed the system by turning the heat on full and the blower on one and that should start the coolant circulating by the auxiliary pump but nothing happened when i did that. What is the pump meant to do ? Cheers boh |
Ignition on, fan on 1, heat fully up - you should head the heater pump running. You won't see water circulation anywhere, but it helps to push the air out. A slight backward incline might help. I haven't re-read the thread, but I recall you have LPG - is the vaporiser below the expansion tank? |
i am not the OP and no LPG to worry about thankfully and i did bleed the system successfully once i put the front up on ramps. the meeknet site said you should see coolant coming through the little squirty bit just inside the cap which i do get but only when i squeeze the pipes and cant hear any pump running...
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
HC, my old gas p38 used to collect loads of condensation in the oil. Same story, loads of short journeys.
Thanks for the heads up, I am waiting on the leak down tester to arrive and i have ordered some enthusiasm which will hopefully get here by the weekend and weather permitting i will give it the full going over.
Errrrr so out head gasket went so got it repaired with a rebuild specialist.
I know what plug you mean, there is a spare plug that sits under the top cover on mine that does nothing but i am not entirely sure the 80 degree mod wasn't my downfall as i had an airlock around the stat that i only discovered after having issues of low engine oil pressure. i raised the front of the RR up on a ramp and got loads more air out of the system and the bottom rad hose was then warm rather than cold as before but the engine was in trouble by then.
No worries buddy.
