Home > Maintenance & Mods (L322) > 7-13pin towing electric upgrade instal question |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
I just unplugged mine and plugged the new 13pin into the big grey plug.
24th Feb 2021 3:37pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 345 |
To be fair it went well, the plug in the car went through the hole in the crossmember so i was able to wire it all up on the bench and fit to the tow bar then simply pass the plug through the hole, a little grease on the grommet and it popped into place only problem is i went to push my 13-7 adapter in and it wouldn't go in the three pins and the slot just didn't line up and it feels solid and i assumed they twist on, should the inside of the adapter spin, sorry for my ignorance but i haven't used these before 2012 Range Rover Westminster 4.4 TDV8
24th Feb 2021 5:29pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
I’ve had difficulty with my adapter too. The L405 needs one while the L322 has the N and S setup. One day I ended up taking the l322 as I couldn’t get the plug in the 13pin in the L405! The adapter does spin in the casing but mine was a bit difficult. I put some lube on it and worked it round gently with some long nose pliers. It makes it easier to plug in now. |
24th Feb 2021 7:36pm |
