Home > Technical (L322) > 2004 L322 making vibration sound between 50-65mph? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3139 |
Torque converter on its way out? |
2nd May 2016 9:56pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
^ +1... Sounds like the TC to me too |
2nd May 2016 10:14pm |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 |
Hi thanks for the replies, if it's the Torque Converter what is the implication of not changing it till it fails completely - will that mean it damages the gearbox or will it just mean the torque converter needs replacement? Does anyone know how much I should be paying for the part and labour for replacing it? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
2nd May 2016 10:50pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
That noise is caused by the lockup clutch failing when it's trying to engage to lock the input shaft to the TC and breaking up. I had the same thing a couple of years ago, should be around £700 for a new TC and fitting. I decided to have the gearbox refurbished at the same time as they had to take it out anyway to fit the TC so was round £1200-1300 from what I can remember. Took about 4 or 5 days to get it done.
3rd May 2016 7:28am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
If the TC is starting to fail it will be burning/breaking up the lockup clutch lining.
3rd May 2016 10:20am |
Does anyone know any decent transmission specialists in the warwickshire/midlands area that they can recommend to do the work or is this something any competent mechanic can do without any special tools or software? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
3rd May 2016 11:04am |
