![]() | Home > Technical (L322) > Wipers a bit erratic... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7903 ![]() ![]() ![]() |
So, yesterday, left work with the auto wipers on, it was raining, they worked, but occasionally parked diagonally across the screen...
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 ![]() ![]() ![]() |
I had something similar towards the end of last year although in addition to the erratic behaviour, the wipers stopped working completely after a while until I turned the engine off and on. Not ideal in the rain!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
I had the same problem, then remembered I'd left my spare sarnies under the bonnet and they had got in the way of the wiper motor.... Most people won't understand this but you know what I mean Mark.... |
So.... How would a dodgy wiper motor make it do 4 or 5 wipes instead of just the single one when you press the stalk down? Some type or short for the same time?
It's got a circular section with different sized tracks around it to let the motor know where in the arc the wipers are, I would imagine if this was worn or damaged then it could miss reading where it was and carry on for several more wipes before it found itself again....
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 ![]() ![]() ![]() |
Similar, initial behaviour last year, which quickly worsened - likewise, new wiper motor |
New wiper motor purchased from Land Rover at a discounted price of £207 inc VAT.
So.... I'm guessing the little micro switch is the cause here, as they have been fine since the motor swap.....
