![]() | Home > Technical (L322) > 6hp26 bang downshift when coming to a stop in town 2-1 |
This is a known problem with your era gearbox, same with Jags. If I remember correctly (but feel free to check with RRPhil) it was a software update. So you could check with Gap Diagnostics whether the IID tool can update that software. I know the Faultmate can (since I have one and did do various software upgrades with it, including the gearbox).
Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40 ![]() ![]() ![]() |
Same problem, 2007 SC
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Clearing the adaptations is a risky thing, if the box has covered quite a few miles then there will be a degree of wear so it could actually make the box worse, as a few have found. There is a software update available from Land Rover, and this along with an oil change can help if not totally eliminate it.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Yes you can update the gearbox software on the 4.2SC using the IID tool. I did it on mine a few weeks ago, nice an easy. |
OOI: is there a version number, so one knows which one is "old" and which is "new"
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 129 ![]() ![]() ![]() |
ebajema,
For those interested; I took the FFRR to the agents, explained the story and asked if they would hook it up. The kind foreman obliged, (No Charge) came back with an upgraded vehicle, the relevant codes are as follows(scan below) I've only done 60 odd km's, but smooth as silk, so happy ![]() |
Hey Ian, please have a look at this post, it's a bit long but does tell you the history of the issue : http://www.fullfatrr.com/forum/topic17348....ing+rrphil MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
Will do, Thanks ebajema. |
RR-EVO Member Since: 28 Mar 2016 Location: paris Posts: 17 ![]() ![]() ![]() |
Many thanks for those infos and TSB. I'll go to the dealership to have it upgrade |
