Home > My Range Rover > Sick of my RR Vogue :(
Page 1 of 3 123>
PJS
Well guys. When i first got my Range Rover Vogue, 2006, i was over the moon! Loved it!
I still love the car, looks great, and is perfect.
But i've had a few problems with it:
The sat nav/radio stopped working - I found out i needed to change the fuse, no problem.
The parking sensors beep constantly whilst reversing when i first use the car in a morning.
Sometimes the hazard lights randomly turn on
The radio sometimes doesn't work/randomly turns off, won't turn back on then comes back on randomly.
After using the radio for 15 minutes whilst parked, it used up all the battery. Had it charged by the AA, was fine. Now the battery fails on me around once or twice a week. So i've had to buy a pack that boosts the battery (keep it in my boot)
The screen (sat nav/radio) dims randomly.
The screen sometimes stays on when the car is locked, meaning i have to unlock it, turn off the radio/sat nav and then relock the car
Sometimes the suspension randomly goes up and down, then says there is a fault (on the screen computer where speedometer is)
When heating is used, there is sometimes a noticeable noise coming from the vents (something wrong with inside of engine?)
How could I solve all of these problems?
I really want to keep the Range Rover, just sick of the constant problems I have!!
Post #37095 20th Nov 2010 1:49pm
Martin
Site Admin
Have you changed the battery? Low voltage does odd things to vehicle electronics....
Post #37096 20th Nov 2010 2:13pm
PJS
Could that fix all problems?
Post #37098 20th Nov 2010 2:32pm
Martin
Site Admin
Well, running a car with a known duff battery won't help - worth changing, especially with a hard winter predicted.
Post #37099 20th Nov 2010 2:33pm
PJS
I had the battery checked by the AA, travelled a mile and a half, and it charged fully. AA said the battery was fine.
Also been to the local garage for it to be checked and they said that the battery is fully charged, and not losing charge.
I've been told when i change the battery, the car "loses all its electronic/memory etc." or something like that. Is that correct?
Will it have to go to a dealer to be changed or will a local garage do it? Any specific battery?
Post #37100 20th Nov 2010 2:36pm
sorry to hear that you have had all those issues..
disconnecting the battery does indeed reset the ecu's...
weak batterys throw up so many errors on the RR, it needs a fully charged battery to work its many ecu's properly...its going to be a process of elimination i'm afraid and the battery is the first step...
europarts do a 110amp hour with a 920 crank for £117 [price in october] , its a type 020 bosch... ... - .- -.
Post #37101 20th Nov 2010 3:05pm
Sounds like a battery problem to me
Nice avatar Martin, who are you trying to impress Rolling with laughter Rolling with laughter
Post #37103 20th Nov 2010 3:30pm
joanne
lol Never mind PJS at least you can take some comfort in knowing that you drive one of the most looked at motors on the uk roads.... unlike some ( i will refrain from cayenne bashing) but you know who you are lol
Post #37107 20th Nov 2010 3:37pm
Reformed
Being a Porsche man I nearly brought a Cayenne!
That said, after looking at them I decided that the Range Rover is still the best! So thats what I traded the 911 up for!!
Think I am going to get a new battery then, as mine has a few minor electrical gremlins.
Post #37122 20th Nov 2010 4:02pm
joanne
Bet youre glad you didnt....
Post #37131 20th Nov 2010 4:43pm
PJS
Thanks guys. What happens if it does reset the ecu etc?
Will I need a garage to fit the battery?
Best battery to get?
Post #37132 20th Nov 2010 4:45pm
Martin
Site Admin
You will probably lose your radio and clock settings (and things like average MPG, trip, etc).
You don't need a garage to change it, just a spanner or two and 15 minutes - depends on your confidence to do it Smile
Post #37135 20th Nov 2010 4:47pm
PJS
Ah I'm not fussed about that stuff.
What make of battery is best and any specs needed?
Post #37152 20th Nov 2010 5:02pm
looked into this before i brought mine and this is the best value and spec...
Post #37163 20th Nov 2010 5:10pm
PJS
Thanks! I think I'll go buy one and see how it goes
Post #37176 20th Nov 2010 5:24pm
Page 1 of 3 123>
