Home > Technical (L322) > Suspension fault
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Suspension fault
Hi I have 2006 td6. Have a fault on suspension . If I lower suspension for access drive away it returns to normal ok but a few mins later it bongs suspension lowered & red lamps on switch go out . Next time travelling on motorway at 75 bong warning saying low suspension only no red lamp on switch. If I stop engine remove key it resets itself fault cleared could be ok then for a week . Went out today started engine. Bong switch lamps came on normal & lowered at same time ..dash saying low hight only . Had to do hard battery resett this time . All working ok now Big Cry any advice please
Post #382637 17th Apr 2016 7:26pm
Get the codes read, should help... could be a height sensor to a small hole somewhere.... Pete
Post #382648 17th Apr 2016 11:07pm
Swiftman
Suspension
Ok thanks will try that first seems to be ok again now fingers crossed thankyou.
Post #382689 18th Apr 2016 9:58am
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Hey Swiftman
Did anything else ever happen with this?
It just happened to me.
Drove 50 miles with the "suspension lowered" error.
Lights out on the suspension switches.
Sat the car for 30 mins and the fault was gone.
All back to normal.
It was very cold today -3 to 5 degrees, thought it might be due to weather.
Post #414549 20th Nov 2016 6:08pm
Swiftman
Suspension
Hi had the fault. On& off for over a year got worse during the summer. Got the codes read quite a few showed up had them all reset next time it happened. Took it back to my Indi he checked found fault was on steering angle sensor. He reset it and it was ok but I have since sold car. So don't know of that cured fault. Brian 2006 vogue se td6 silver. Bailey unicorn 3 Cadiz . Discovery td5 & many other types before.
Post #414552 20th Nov 2016 6:29pm
Cooper1275
Il keep an eye on it so!
Thanks mate much appreciated
Post #414554 20th Nov 2016 6:34pm
