Home > Off Topic - Other Cars > Anyone know about bike engines?? Help !!
Rosco
Hi, have acquired a bike with a single cylinder aircooled Kohler petrol engine, was fine for 2 days but now is a pig. It starts and idles no problem, as soon as I put on any throttle it sounds strangled and then will die if returned to idle!! I know zip about bikes and cant seem to find a fuel filter as that was my first thought.
Do any of you helpful chaps/chapesses have any tips
thanks in advance, SWMBO is questioning my man maths on this one Rolling with laughter
Here is the offending thing
Post #382320 15th Apr 2016 8:34pm
mzplcg
Well I'm not familiar with that specific engine but you're right to be looking at fuel. Possibly a carb diaphragm, partially blocked jet, blocked filter etc. Basically it's dying because there is too much air for the fuel being delivered.
Carb diaphragm would be my first item to check. Even a tiny split will cause mixture havoc.
They're well known motors though, found in generators, snow-mobiles and a myriad of other items. Spares ought to be readily available.
Post #382328 15th Apr 2016 9:23pm
Found this service agent for Kohler on the web Ross if its of any use , i know they are down south but maybe worth a shout 👍
LOMBARDINI U.K. LTD.
1 Rochester Barn
Eynsham Road
Oxford
OX2 9NH
Phone: +44-1865 863858
Fax: +44-1865 861754
e-mail: salesuk@lombardini.it
internet: www.lombardini.it
Post #382330 15th Apr 2016 9:38pm
Rosco
Thank you gents, I received no back up paperwork so that has given me some good pointers Thumbs Up
Post #382333 15th Apr 2016 9:42pm
Clivefog
Is it new clean fuel?
Filter maybe where the fuel goes into the carb.
If old fuel I'd drain the tank, remove the carb and empty the float chamber, blow through the jet(s).
Refit and fill with a small amount of new fuel.
Remove plug and possibly replace it.
Post #382356 15th Apr 2016 11:02pm
miggit
Duff fuel, your trying to run it on water, or there is a blockage in your jets..... take it to a lawn mower service centre.... it's a lawn mower engine and the parts are cheap, you'll more than likely get a new carburettor for less than £30.00 Shocked Do a search for parts for the engine, NOT the bike!
If it turns out to be water in the float bowl, I would recommend that you drain the tank and decant the petrol from the water with the aid of a glass jar..... the water will be yellowy bit at the bottom of the jar Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #382372 16th Apr 2016 12:08am
miggit
Don't know the engine number but this is the sort of thing that you should expect http://www.ebay.co.uk/itm/Gasoline-Carbure...GkavFjj_Tg Yesterday I couldn't spell Engineer... Today I are one!
Post #382378 16th Apr 2016 12:49am
