Home > Technical (L322) > Key Programming |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
remember, when you sync a key you must do all your keys, repeat the process one at a time for each key, do you just need the internal circuit board for the key as this part can be used from a second hand unit..
19th Feb 2012 9:12am |
it can happen, if the remote has not synced with the ecu when starting it can loose the rolling code, firstly you need to re-sync the key, again if you have two keys you will need to sync the pair. why your alarm is going of is an other matter,check that all your windows are fully up, check the bonnet switch,you can set the alarm and with an other click it should disable the ultrasonics, i think thats right will have to check unless someone can back it up... V8 facelift Range Rover Autobiography 22" wheels.
19th Feb 2012 6:01pm |
Nod 1 Member Since: 05 Oct 2009 Location: Burnham Posts: 20 |
Sorry forgot a to mention, I disconnected bonnet switch last week after reading the relative thread. One thing I have noticed is that key can stick in lock and not turn fully. This has only happened in recent weeks. Could that be anything to do with it ? |
19th Feb 2012 6:14pm |
Hi Daveo
20th Feb 2012 4:35pm |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
Hey guys,
3rd Apr 2012 9:49am |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 |
I was recently relieved of £215 to get a second key for my 53 plate vogue. Luckily I read this post before i went to dealers and declined their 'programming service' saving me a further small fortune which, for that price for the key, you would think they would do it for nothing. Took me about 17 seconds to do 2007 3.0L Diesel VW Touareg SE
3rd Apr 2012 10:02am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6716 |
Just to muddy the waters a bit more, I've noticed that the battery in my spare key seems to have died as it doesn't open the doors etc remotely, but will open the doors using it in the lock and start the car, so what's the deal for changing the battery? Does it need recoded or anything once the battery has been replaced? Got - 2017 SDV8 Autobiography in Loire Blue
3rd Apr 2012 10:22am |
my battery died completely without warning. reading elsewhere this is not uncommon. i went to LR who advised me to buy from tesco or somewhere else as their price was £8 per battery. The guy made it quite clear to only use a 2016 as the other flat battery types could cause damage. i bought 2 x 2016 for a fiver whilst out shopping and just did a straight swap when home with no issue. However i did then have a go at the 'programming' just to see how difficult it was and found it real easy especially as i only had one key at the time. 2007 3.0L Diesel VW Touareg SE
3rd Apr 2012 11:22am |
Cheers for the battery info. Since mine is an MY07, I would assume the programming bit won't work........ Got - 2017 SDV8 Autobiography in Loire Blue
3rd Apr 2012 11:38am |
alib123 Member Since: 29 Dec 2013 Location: essex Posts: 20 |
Hi Nod1, i had the same issue last night with alarm going off and brake lights on, did you find a solution? |
11th Jan 2014 10:05am |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
re brake light problem, if you cant turn the ignition key in the lock try cleaning the ignition switch. I had the same problem search my posts for what I did have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
11th Jan 2014 4:59pm |
Jovinblak Member Since: 11 Jun 2014 Location: Hertfordshire Posts: 9 |
Got my 2002 4.4v8 with only one key, contacted main dealer after checking in Microcat, dealer quoted £180 for key + £60 for programming, so took a chance and ordered a blank with electronics from ebay £27.34 with postage, it arrived two mornings later, with guidance from this site using the procedure mentioned, I now have two keys that lock/unlock and have found someone who will cut the blank from a photo of the original for a tenner, he also supplies empty cases cut to match for £15 quid if your original is worn as is mine, all I need do is swap my electronics over to the new empty one, will post back once done to confirm I can start the engine, but if it locks and unlocks, I'm sure it will. Hope this helps save people money, as there's no choice but dealer with the P38s.
11th Jun 2014 3:10pm |
hi you will find the new key will lock and unlock but will not start the car, you need a new transponder coded to your car...and you will find that the dealers will not supply you with one unless they supply a whole key, i can code transponders but its a car in front of me job..
11th Jun 2014 6:46pm |
That's bad news Daveo, on the other hand, good news if you can do it depending on cost and your location in relationship to mine, just north of London, The key cutter, is I believe, Express Auto Keys in Orpington, keysinthepost.com, but considering the cost from Landrover, it was worth the gamble, not lost a lot and still have a spare case or a key that unlocks the car. Let me have the relevant information and I will get back to you when I get my keys back cut.
11th Jun 2014 7:45pm |
