![]() | Home > Technical (L322) > TDV8 no power, white/blue smoke |
gsmith1 Member Since: 13 Dec 2012 Location: Australia Posts: 6 ![]() ![]() |
Hi rar110,
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Gday
Thanks rar110, I ordered a set today from Auto Code, www.autocode.com.au
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
http://store.autocode.com.au/egr-emulator.html
It runs a bit quieter and much less black smoke out the back on acceleration. I read that the EGR helps bring the motor up to temp a bit faster. I tend to give it a little more time to warm up before I give it a boot full. And you don't get the EGR cycling noise on shut down. ______________________________
Very tempting for when the RGR's finally throw in the towel.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1463 ![]() ![]() |
My understanding is that, in the UK it will fail an MOT if the EGR's are by-passed or disconnected.
Whys is that? Does it have an effect on the emissions check? Got - 2017 SDV8 Autobiography in Loire Blue
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
If it was fitted with EGR from the factory, then it has to be present for MoT. Same for DPF and Cats.
So, assuming the MOT tester probably won't even open the bonnet, it's a bit of a moot point then? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
it is a moot point, however assuming they are plug and play, then you could just plug the EGR back in for the MOT |
I doubt an inspection would identify what it is if the bonnet was opened. But yes can be put back to factory in a couple of minutes by unplugging the emulators and plugging in the EGRs. ______________________________
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I had my EGRs turned off a few weeks ago and it has stopped the puff of smoke that used to appear on initial hard acceleration It was done while being remapped with no extra cost 2015 4.4 AB
Who did the remap? ______________________________
