Home > Technical (L405) > TPMS - Not working?
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
TPMS - Not working?
So my wife's car say something about light load when you start it up and it's checking pressure etc..
So I was playing to see a little more and found you can select in the in car menu light and heavy load etc.. I also found an area where you could check the tire pressures.
A little picture pops up showing the wheels and the recommended pressure in brackets but the number before that was always 0, which I assumed was supposed to show me the actual pressure?
Is my assumption right and if it is has it been disabled and hence now showing 0. If so can I get it reenabled?!
Searching some threads I'm wondering if the TPMS is a pain in the rear possibly of was this a problem on the L322s?
Thanks
Post #380034 30th Mar 2016 7:17am
I guess first thing to check would be that the wheels have TPMS valves in them - they will be metal as opposed to normal rubber valves.
I had no end of trouble with it on my L322, so my L405 doesn't have it fitted so I can't be of much more help.
Post #380040 30th Mar 2016 9:13am
Your L 405 dos not have TPMS ? Alistair ? Doesn't it come as a standard ? Shocked All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #380043 30th Mar 2016 9:33am
It didn't come standard until it was a legal requirement sometime in 2014 I think - mines a late 13 VSE and it was an option then.
Post #380044 30th Mar 2016 9:44am
i see - well i got it and it is an early 2013 from march.... Confused All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #380045 30th Mar 2016 10:02am
We have the metal air intakes if that is what we should have for TPMS?
I think it's still an optional extra on the Landrover Build your own Car system although maybe not but I'm amazed it wasn't standard I agree.
Post #380047 30th Mar 2016 10:18am
You checked on Topix ?
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #380054 30th Mar 2016 10:50am
Yes we have it on Topix too. I guess if we didn't the sensor information wouldn't show in the dash either at all?
Post #380056 30th Mar 2016 11:06am
hmm i never bother...... All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #380058 30th Mar 2016 11:13am
