![]() | Home > Technical (L322) > Suspension fault ? |
Had the car lowered? Did you cycle the ignition and restart? Did the problem persist? If so, leave car overnight and report tomorrow mornings findings sir... |
Wagon mark Member Since: 23 Mar 2014 Location: Sheffield Posts: 26 ![]() ![]() |
Yes I tried turning it on and off a few times and just kept saying same thing then did 100 miles in it back home car looked like it was at the normal height |
OK, so you have two chances... A, leave the car to shut down/sleep then re-try and hope it now has resolved itself... or B, do a battery reset and hope the issue is not a stored fault in the ECU...
Will leave it a couple of hours and see what happens is there anything that's common for causing this problem? Thanks for your help |
Could range from being a bad battery to a height sensor or worse still a worn compressor... If the car is keeping good height then i would suggest its NOT got an air leek... Height sensors are quite common, but then so are most faults |
Thanks again for your help will let you no what happens on restart if no joy off for a scan it goes yes keep looking at Iid tools think could be an investment with this car |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
"air leek" (snigger!!)
Is there any fuses I can pull to reset suspension if so where ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8512 ![]() ![]() ![]() |
No, has to be reset with a diagnostic tool... Pete
OK cheers |
Plugged car in to smart charger last night worked fine this morning no warnings and lights working on height switch could it just have being a low battery ? |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
Just been reading through some posts & wondered if you ever foung the fault on your suspension as I have 2006. With much the same fault . Get a bong sus lowered . Have to stop switch of remove key wait a few seconds & restart car most times this clears fault . Could be OK then for another week Help |
Hi yes still got same fault charged battery up and all seemed good for about a week read up on here and stripped compreser in boot removed dryer and emptied out on a baking tray and in the oven it went put it all back together and worked perfectly till tonight on way home from work and ping suspension fault normal ride height only message back and lights on switch gone out again so who knows back in for another scan to see what it says now will let you no verdict of diagnostic |
Ok thanks if I find a cure will let you know . Good luck |
