Home > Technical (L322) > Suspension fault ?
Wagon mark
2006 Range Rover Vogue SE Td6 Santorini Black
Suspension fault ?
Got in my 06 Vogue se this morning drove a couple of miles parked came back to car started it up and got message saying suspension lowered warning and lights gone out on suspension height switch car seems to drive OK any ideas to my problem thanks
Post #379793 28th Mar 2016 5:21pm
Had the car lowered? Did you cycle the ignition and restart? Did the problem persist? If so, leave car overnight and report tomorrow mornings findings sir... Thumbs Up
Post #379796 28th Mar 2016 5:25pm
Wagon mark
Yes I tried turning it on and off a few times and just kept saying same thing then did 100 miles in it back home car looked like it was at the normal height
Post #379797 28th Mar 2016 5:32pm
OK, so you have two chances... A, leave the car to shut down/sleep then re-try and hope it now has resolved itself... or B, do a battery reset and hope the issue is not a stored fault in the ECU...
If either of the above does NOT resolve the issue then a plug into diagnostics will be needed sir Rolling Eyes
Post #379800 28th Mar 2016 5:37pm
Wagon mark
Will leave it a couple of hours and see what happens is there anything that's common for causing this problem? Thanks for your help
Post #379804 28th Mar 2016 5:42pm
Could range from being a bad battery to a height sensor or worse still a worn compressor... If the car is keeping good height then i would suggest its NOT got an air leek... Height sensors are quite common, but then so are most faults Rolling Eyes
If the system does NOT come back to life after a sleep (but keeps its height) then a plug in is your next logical step sir Thumbs Up
Search IID tool on here ^ top of page use �search� button... Does all the diagnostics for you and saves you a fortune on MD rates sir Thumbs Up
Post #379806 28th Mar 2016 5:50pm
Wagon mark
Thanks again for your help will let you no what happens on restart if no joy off for a scan it goes yes keep looking at Iid tools think could be an investment with this car
Post #379811 28th Mar 2016 6:03pm
"air leek" (snigger!!)
Post #379814 28th Mar 2016 6:27pm
Wagon mark
Is there any fuses I can pull to reset suspension if so where ?
Post #379815 28th Mar 2016 6:35pm
No, has to be reset with a diagnostic tool... Pete
Post #379822 28th Mar 2016 6:58pm
Wagon mark
OK cheers Thumbs Up
Post #379845 28th Mar 2016 8:39pm
Wagon mark
Plugged car in to smart charger last night worked fine this morning no warnings and lights working on height switch could it just have being a low battery ?
Post #379877 29th Mar 2016 8:32am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Suspension. Wagon Mark
Just been reading through some posts & wondered if you ever foung the fault on your suspension as I have 2006. With much the same fault . Get a bong sus lowered . Have to stop switch of remove key wait a few seconds & restart car most times this clears fault . Could be OK then for another week Help
Post #384118 27th Apr 2016 6:54pm
Wagon mark
Hi yes still got same fault charged battery up and all seemed good for about a week read up on here and stripped compreser in boot removed dryer and emptied out on a baking tray and in the oven it went put it all back together and worked perfectly till tonight on way home from work and ping suspension fault normal ride height only message back and lights on switch gone out again so who knows back in for another scan to see what it says now will let you no verdict of diagnostic
Post #384162 27th Apr 2016 9:52pm
Swiftman
Suspension
Ok thanks if I find a cure will let you know . Good luck
Post #384163 27th Apr 2016 9:54pm
