![]() | Home > Maintenance & Mods (L322) > Detachable tow-bar on 2012 TDV8 Westminster? Advice please.. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
Well I have one on mine.....
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Definately do. I had one fitted to mine with OE harness for around £600. |
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 ![]() ![]() ![]() |
McFly, could I suggest you are maybe a little more general with your location ? |
Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76 ![]() ![]() ![]() |
Sorted, thanks for pointing it out. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
The best tower is the Westfalia one - that is the one that was original equipment on the car.
Pretty good video here |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Hi have to say I spent a lot of time looking at detachable towbars before making the jump. PFJones were in actual fact less than helpful and still quite expensive.
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 ![]() ![]() ![]() |
Having just had to resolve a related issue myself, think about what you plan to tow, and the required ball height. The 'drop plate' type hitch allows for the towball to be higher than the 'whale cock' type. If you tow a caravan then the latter is probably ideal, if you to larger 'commercial' type trailers then you will probably need the extra hitch height afforded by the drop plate type in order to tow level.
Thanks gents, much appreciated!! Quality information to peruse.
Quick update (and hopefully helping someone in the same position as me):
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
My PF Jones kit was plug and play on MY11.5
Am I wrong thinking 'plug & play' means that no coding is required?
