Home > Maintenance & Mods (L322) > Detachable tow-bar on 2012 TDV8 Westminster? Advice please.. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Well I have one on mine.....
24th Mar 2016 10:27pm |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Definately do. I had one fitted to mine with OE harness for around £600. |
24th Mar 2016 10:40pm |
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 |
McFly, could I suggest you are maybe a little more general with your location ?
24th Mar 2016 10:42pm |
Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76 |
Sorted, thanks for pointing it out. |
24th Mar 2016 11:26pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7947 |
The best tower is the Westfalia one - that is the one that was original equipment on the car.
25th Mar 2016 8:09am |
Pretty good video here
25th Mar 2016 8:41am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Hi have to say I spent a lot of time looking at detachable towbars before making the jump. PFJones were in actual fact less than helpful and still quite expensive.
25th Mar 2016 9:49am |
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 |
Having just had to resolve a related issue myself, think about what you plan to tow, and the required ball height. The 'drop plate' type hitch allows for the towball to be higher than the 'whale cock' type. If you tow a caravan then the latter is probably ideal, if you to larger 'commercial' type trailers then you will probably need the extra hitch height afforded by the drop plate type in order to tow level.
25th Mar 2016 10:03am |
Thanks gents, much appreciated!! Quality information to peruse.
25th Mar 2016 1:41pm |
Quick update (and hopefully helping someone in the same position as me):
12th Apr 2016 12:32pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
If you buy the Westfalia wiring kit from PF Jones it does not need to be programmed, it is the same as the Land Rover kit only a third of the price. The only kits that have to be programmed are the after market kits, which are priced around £50 as opposed to £84 for the westfalia kit, when you add the cost of a trip to L/R to have the CCF programmed, the £84 Westfalia kit is the cheapest Factory Standard and only differs from the genuine L/R kit by not having the L/R stickers on it You might save £30 on the equipment but you'll have to spend another £160 getting it to work, or you could fit the genuine L/R stuff @ £160+ .... I'd rather forgo the stickers and the dealer programming and just plug and play.........
12th Apr 2016 10:38pm |
And now having looked at PF Jones, it would appear that all that I have said is true for 2002-2009........
12th Apr 2016 10:44pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
My PF Jones kit was plug and play on MY11.5
13th Apr 2016 9:29am |
Am I wrong thinking 'plug & play' means that no coding is required?
13th Apr 2016 12:54pm |
