Home > Technical (L322) > Help with Transmission faults
koffeetemple
Australia 2009 Range Rover Autobiography TDV8 Zambezi Silver
Well folks see if you can help me with this
I have a 2009 FFRR Vogue with 3.6L TDV8
It is coming up with the following codes
P0730-00 Incorrect gear ratio
P0735-00 Gear 5 incorrect ratio
U0401-94 invalid data received from engine control module/powertrain control module
U0402-94 invalid data received from transmission control module
U0416-94 invalid data received from vehicle dynamics control module
U0403-94 invalid data received from transfer case control module
This only happens when towing (we tow a horse float 1.6 Tonne), with out the float no problems
It goes into limp home mode and comes up with a transmission error saying limited gears
When we use the manual selection and keep RPM up around 3000 - 3500 no problems
Could it be the Torque converter, valve bodies?
I have had the oil changed and it was very dirty and when this started i had the fluid changed a second time
Please help if you can
Thanks
Damien
Post #378816 22nd Mar 2016 12:40am
My suggestion would be to consult a ZF specialist sir... I think its better sooner rather than later too sir Thumbs Up
Post #378834 22nd Mar 2016 8:50am
this site has some info that might help,
http://www.obd-codes.com/p0730 ... - .- -.
Post #378838 22nd Mar 2016 9:10am
