Home > Off Topic - Other Cars > Freelander problem |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi guys
9th Mar 2016 7:41pm |
I dont think the Pressure sensor is that much money compared to a recon pump and worth a shot as i think they are £40+
9th Mar 2016 11:44pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1766 |
There is a known issue with the rail pressure sensor wiring, and a repair loom
10th Mar 2016 3:45am |
Thanks guys
10th Mar 2016 2:14pm |
It's a known issue of poor pin tension inside the connector, causing an open circuit issue, regardless of continuity back to the ECU |
10th Mar 2016 5:28pm |
Ah, thought is was just broken cables and corrosion in connectors. AA man did give the connectors a good wiggle while I cranked the engine and readings didn't change 56 TDV8 Vogue SE
10th Mar 2016 6:06pm |
The overlay harness is less than £40
10th Mar 2016 9:04pm |
Not tried it with easy start yet. I will get some at the weekend and give it a shot 56 TDV8 Vogue SE
10th Mar 2016 10:11pm |
eventually got this fixed. despite all my testing showing it was not the wiring to the HP sensor Mikey was correct . It turned out to be internal failure of the connector 56 TDV8 Vogue SE
31st Mar 2016 7:10pm |
31st Mar 2016 8:16pm |
