Home > Off Topic - Other Cars > Freelander problem
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Freelander problem
Hi guys
I have a 2003 Freelander TD4 for the daily commute, on Friday it broke down. My diagnostic tool shows no pressure on the HP fuel rail (zero psi). LP side has about 40psi.
I am assuming it is either HP pump, pump regulator or HP fuel rail sensor.
Before I start buying parts, just wondering if anyone has come across this before?
I have checked connectors and cables and they are fine 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #376590 9th Mar 2016 7:41pm
I dont think the Pressure sensor is that much money compared to a recon pump and worth a shot as i think they are £40+
There was a revision to them as well as there is a little filter on them that can block.
Could also be worth checking resistance on it and see if its gone total open circuit... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #376640 9th Mar 2016 11:44pm
Mikey
There is a known issue with the rail pressure sensor wiring, and a repair loom Thumbs Up
Cheapest and easiest place to start
Post #376646 10th Mar 2016 3:45am
Andy_J
Thanks guys
Mike - I have already checked the loom and I have continuity back to the ECU block connectors, also checked power at the HP sensor and have 12v
KP - yep priced the parts, been told best to go with genuine Bosch @ £80.
I am 90% sure it is the sensor not the HP pump.
Will go with that and see 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #376713 10th Mar 2016 2:14pm
Mikey
It's a known issue of poor pin tension inside the connector, causing an open circuit issue, regardless of continuity back to the ECU Thumbs Up
Post #376753 10th Mar 2016 5:28pm
Andy_J
Ah, thought is was just broken cables and corrosion in connectors. AA man did give the connectors a good wiggle while I cranked the engine and readings didn't change 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #376758 10th Mar 2016 6:06pm
Mikey
The overlay harness is less than £40
That said, the PRV in the HPFP could be stuck open, allowing fuel to return straight back to the tank. Does it start with easy start?
Post #376782 10th Mar 2016 9:04pm
Andy_J
Not tried it with easy start yet. I will get some at the weekend and give it a shot 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #376791 10th Mar 2016 10:11pm
Andy_J
eventually got this fixed. despite all my testing showing it was not the wiring to the HP sensor Mikey was correct Bow down . It turned out to be internal failure of the connector 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #380230 31st Mar 2016 7:10pm
Mikey
Post #380244 31st Mar 2016 8:16pm
