Home > Maintenance & Mods (L322) > Painting Headlights
RidgeRover
Painting Headlights
Took the plunge this weekend and painted the Super's headlights black. Thought I'd add some notes here in case anyone else is thinking of doing it themselves.
1) It's much easier than you might think so don't be afraid to give it a go. daveo's instructions on how to dismantle the 06-09 headlight in the Wiki take you through most of what you need to know.
2) Taking the headlights out is a piece of cake - just two screws at the top and one at the bottom and then pull out the wiring connector.
2) If putting your lights in the oven or using a heat gun puts you off, just use a hair dryer. With 2-3 minutes of warming with the hairdryer the sealant separates easily.
3) If you plan to keep the chrome surrounds around the lights DONT use masking tape. I masked them off before spraying and when I took off the masking tape it pulled off bits of chrome which then had to be touched up with chrome paint. Has anyone figured out how to do it without masking tape?
4) Put down plenty of extra news paper around where you are spraying as the overspray may go further than you expect. I had a few frantic moments with the white spirit - and luckily Mrs Ridge Rover didn't notice!!
6) Warm up the sealant on both the body of the headlight and the lens before you try to put them together again, it will make it much easier.
Here's the finished product:
 Put two Rhodeasian Ridgebacks in a Range Rover and pretty soon it's their Ridge Rover.
Post #375992 6th Mar 2016 4:42pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
looks nice.
Post #375993 6th Mar 2016 4:55pm
You can buy low tack masking tape or just pull off a length then wipe the sticky site across your trousers until the tack is reduced....
You can also paint the bit you don't want covered in grease, wait till the paint dries properly and wipe it off....
Or buy some plasti-dip brush on and use that as masking tape, it peals of easily afterwards.... Pete
Post #376015 6th Mar 2016 6:21pm
Oh sorry, and I love the look on a black car... Thumbs Up Thumbs Up Pete
Post #376016 6th Mar 2016 6:23pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Looks very Nice! Thumbs Up
Thanks for sharing.. 2002 L322 V8
Post #376044 6th Mar 2016 10:11pm
You can’t even touch the chrome inside as the salt contained within the sweat in your fingerprints will tarnish it! Shocked
We have always hand painted them negating the need to mask them Thumbs Up
Post #376058 7th Mar 2016 12:58am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Like that! Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #376070 7th Mar 2016 7:37am
verydisco
Top job indeed. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #388273 22nd May 2016 8:32pm
rar110
The new Defender headlights might look something like that. ______________________________
Post #388289 22nd May 2016 10:05pm
