Home > Maintenance & Mods (L322) > Solar Powered Panel Battery Trickle Charger
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Anyone tried one of these?
http://www.ebay.co.uk/itm/Solar-Powered-Pa...SwibFUYJF5
Many thanks
Ian
Post #375632 3rd Mar 2016 10:55pm
rangie47
hi Ian,
I've got 1 of these, had it a few years ,
http://www.towsure.com/fold-up-portable-solar-panel-kit-4-watt
used on my td5 disco, sons jeep and my caravan.
excellent bit of kit for the money,
terry 2007 tdv8 se ,stornaway grey
Post #375643 4th Mar 2016 1:17am
johnboyairey
I've been looking at these and wondered if any members have a decent one. I see that typical ones of about 5 watts seem quite cheap, (China sourced) at around £20 but I seem to remember reading, you need a sort of regulator, to get it to work....better.
No doubt there are ones within built in.
I had wondered if I could get a super slim type, and have it built into the sunroof's blind tray, though the roof glass is slightly tinted... Or a pair on the rear parcel shelf side panels. For cheap money, I'm happy to try, but I don't want to find I fry the electrics, with an over voltage, on a baking hot day.
So, experiences here please.
It's kind of a given, that having an l322 means you HAVE to be a two car household....to guarantee a quick jump start, should your battery be flat! Shocked
Post #375661 4th Mar 2016 9:21am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I use a 5 watt one on my boat and it keeps everything ship shape throughout the summer. Can go 3 weeks between trips and if the auto bilge is running a lot it still keeps up. This was from the bay at £35 ish and it does have built in regulator. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #375664 4th Mar 2016 10:08am
Emperor Mong
I used to have one (not sure what type) on the back shelf of my L322 24/7. Kept the battery topped up as I tend to do lots of short journeys.
Post #375667 4th Mar 2016 10:16am
I have two that I leave on my boat through the winter - it has dual batteries - and seems to keep them charged up & ready for use each spring.
Not sure how much use it would be on a FFRR through the winter though - unfortunately peak battery load coincides with the least sunlight - but I guess that every little helps.....
In fact mine are the exact same ones - bought from a Maplin store when they were on a similar offer - cheaper than the one half the size Confused
Post #375672 4th Mar 2016 10:25am
Emperor Mong
That was my logic - every little helps. I never had a problem. Would I have had a problem without it? No idea!
A bit like that old joke about a chap who bought some magic beans to protect him from werewolves. When asked by a friend why he'd ever do that, he replied "because they work! Since I bought them, I've never been attacked by werewolves, so they are excellent".
Post #375696 4th Mar 2016 2:17pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Surely at 4w the charge is so small it will be of no use. It wouldn't even run the internal lights.
Post #375697 4th Mar 2016 2:20pm
That eBay one is 2.4watt... a massive 0.2amps....!!!!!! and that's in direct sun light
Don't think that would do much, your going to need a much bigger one for a FF during the winter....
These are designed to keep a charged battery topped up, a decent battery will lose less than the 0.2amps supplied by it so if it's in a boat/caravan etc doing very little to nothing then it will keep the battery charged, it won't work to replace any significant draw from a battery...
Remember your alternator is designed to do that and it puts out 150amps... 750 times more than the solar panel.... Pete
Post #375704 4th Mar 2016 2:41pm
It's 4w more than you're getting without it....... Whistle
I kind of assume that a battery is always draining slowly - so this is enough to replenish what is otherwise wasting away and maybe a little more.
I've not bothered on a FFRR, but I can't see it doing any harm - and would make some sense for a car not getting regular use.
Post #375708 4th Mar 2016 2:57pm
babagee
Thanks for all you input
Going to invest £15 of hard earned cash as the RR is going to be parked up for a few weeks
Will report back
Ian
Post #375754 4th Mar 2016 7:37pm
Weegie
Looking at your link it isn't clear if there is any form of regulator with it. It rather appears as if there isn't. You need at least a diode to make it "one way" to avoid the battery discharging back through the panel when there is no light on it. John
GAP iiD BT-Sold
Post #375755 4th Mar 2016 7:42pm
lighthouse
still would guess that 4 watts would barely cover the alarm draw.
Post #375771 4th Mar 2016 8:33pm
babagee
From ad
Built-in diode prevents reverse charging
Post #375779 4th Mar 2016 8:57pm
Weegie
Thumbs Up Didn't see that. Better sure than sorry. Wink John
GAP iiD BT-Sold
Post #375780 4th Mar 2016 9:07pm
