![]() | Home > Maintenance & Mods (L322) > Solar Powered Panel Battery Trickle Charger |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
Anyone tried one of these?
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
hi Ian,
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I use a 5 watt one on my boat and it keeps everything ship shape throughout the summer. Can go 3 weeks between trips and if the auto bilge is running a lot it still keeps up. This was from the bay at £35 ish and it does have built in regulator. 2017 5.0 Autobiography Supercharged
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I used to have one (not sure what type) on the back shelf of my L322 24/7. Kept the battery topped up as I tend to do lots of short journeys. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
I have two that I leave on my boat through the winter - it has dual batteries - and seems to keep them charged up & ready for use each spring.
That was my logic - every little helps. I never had a problem. Would I have had a problem without it? No idea!
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Surely at 4w the charge is so small it will be of no use. It wouldn't even run the internal lights. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8560 ![]() ![]() ![]() |
That eBay one is 2.4watt... a massive 0.2amps....!!!!!! and that's in direct sun light
It's 4w more than you're getting without it....... |
Thanks for all you input
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Looking at your link it isn't clear if there is any form of regulator with it. It rather appears as if there isn't. You need at least a diode to make it "one way" to avoid the battery discharging back through the panel when there is no light on it. John
still would guess that 4 watts would barely cover the alarm draw. |
From ad
