Home > Technical (L322) > GEARBOX D'OH!!!!!!!!!!!!!
Page 3 of 6 <123456>
miggit
The remap figures are only what I've read on line... Whistle what ever they are, everyone us quoting 20 hp more than the top ffrr figure. If I can get it to do what I need it to do without a remap, all well and good, but if it's in need of a little boost to maintain lockup speed so be it Thumbs Up
It surprises me that there isn't a gearbox conversion for the TD6 available.... after all the GM box wasn't the only one used with that engine.... and there are a lot of better gearboxes used in the later versions... lets face it BMW are getting TDV8 power out of the Bi Turbo X5's Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #375278 2nd Mar 2016 11:25am
Lost for Words
I guess the difficulty is integrating it with the rest of the car's systems correctly. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #375279 2nd Mar 2016 11:36am
miggit
Are but the 7 series BMW used a ZF box with that engine, so there must be an ECU that talks ZF 5 speed that the rest of the car will understand..... And maybe the later 6 / 8 speed boxes can be made to talk as well.... and then I do believe that Manual was available on the X5, so I can't see why that couldn't be made to fit..... And although I'd prefer an automatic box, at least with a manual I could leave it in say 4th gear and not have to worry about the Censored clutch slipping all the time, like the bloody GM box does.....
I wish that I had the abillaty to re program the ECU cos the more I think about what the gearbox does and what it should do.... I end up with the realisation that it was programmed by someone who has no idea about towing and only understands how to get a soft gear change..... the bloody tow mode makes things worse for the gearbox not better Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #375290 2nd Mar 2016 12:18pm
Lost for Words
Yes, it's not beyond the realms of possibility to achieve it, but I suspect that the LR differences mean the whole lot has to be reprogrammed etc. Thumbs Up Visiting from DISCO3.CO.UK
Post #375299 2nd Mar 2016 12:34pm
Keep FF... fit one of these.... job done.... Thumbs Up Thumbs Up
http://lisupercars.com/getawaycarz/5l40e%20shift%20kit.htm Pete
Post #375305 2nd Mar 2016 12:57pm
miggit
Nice idea, but I don't really want to be choosing every gear and gear change.... that's why I got an automatic!
And there are 2 problems that I can see, firstly they don't list the Range Rover.... that could be an issue, and secondly, HOW MUCH Shocked By the time I've paid shipping and Vat I'll be close to the cost of a new box Shocked
If I end up keeping it I will be looking in to the ECO tune remap, my only worry is what happens when the car's been told it's in tow mode..... what does the box do then? if it still fully locks then great, knowing my luck it will go in to clutch munching mode Censored If only there was a way to override the ECU and hard wire the lock up. We shall see, I'd rather not get shot as it is the devil I know, rather than take a chance on another car, but if it really isn't man enough for the job, I will still be flogging a dead horse Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #375331 2nd Mar 2016 3:47pm
Weegie
You have probably seen this, and TBH it probably doesn't take you any further, but it might give some ideas as to what is and what isn't possible.
http://www.aulro.com/afvb/l322-range-rover...tions.html John
GAP iiD BT-Sold
Post #375336 2nd Mar 2016 4:40pm
miggit
Big Cry I'm DOOMED Big Cry Looks like even a manual conversion is off the cards as the engine will sulk Evil or Very Mad
So I'm back to getting the Censored thing fixed, and then change it for something more suitable for heavy towing Big Cry I really liked my ffrr, except when it's throwing its' little hissy fits, which is a fair bit at the moment... maybe I wont miss it that much Evil or Very Mad
Why does it all have to be so complicated now-a-days ? there was a time, when if it could be made to fit it worked, now even if you get it to physically fit it wont work cos the bloody ECU's wont talk to each other Censored Censored Banging Head Yesterday I couldn't spell Engineer... Today I are one!
Post #375350 2nd Mar 2016 5:51pm
sako243
Funnily enough I was reading through the TDV8 manual a few months ago and (relatively speaking) thinking how simple it would be to design a circuit to make the engine be an engine...
If someone could set up the "tune", i.e. telling me when to fire an injector with respect to something else then it would be pretty simple. All the sensors are there and the workshop manual basically tells you most of what you need to know about how to talk to them directly. The rest can be figured out from an oscilloscope.
No farting around with reprogramming ECUs etc. just take sensor feeds directly in and outputs to injectors etc and bobs your uncle.
If I could find a similar manual for the gearbox then that could be done as well. Although if the engine became an engine then you could just put a manual on it... Ed
Post #375564 3rd Mar 2016 4:45pm
RiccartonRR
miggit wrote:
I raise you Rolling with laughter
3.6 TDV8 towing 5.2te (inc' trailer). The FF did this many many times and the trip included a mile up a 1 in 8 plus several shorter but steeper climbs yet never had to come below 45 (B roads - not motorways - so no run up). No problems at all and compared to the D3 before it chalk & cheese (engine not chassis).
Same load, different vehicle
Remapped 2.2 Puma 90. With the gearing advantage it's not too bad and economy wise no different to the TDV8 or D3.
My driving style got me (according to the OBC) 19 from the TDV6, 20 from the TDV8 and 19 from the Puma (brim to brim). Going by that I reckon the Puma is actually the most economical of them all.
TDV6 D3 remapped is great but it aint no TDV8 and for site work you can't beat a Deafner Thumbs Up
Just MHO you understand :whistle:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Back in a Defender!!
Post #375621 3rd Mar 2016 10:00pm
RiccartonRR
^^^^Oops, wrong FF picture Embarassed Embarassed ^^^^ Back in a Defender!!
Post #375623 3rd Mar 2016 10:02pm
miggit
I don't for one minute doubt that the TDV8 ffrr will tow everything that I hook it to.... I just can't afford one, especially with the large Road Fund Tax increase. At least I can get a TDV6 that is with in the same tax bracket as the TD6, and the other consideration is that I only tow for half the distance that I cover, and then I return solo, so the slightly higher MPG from the TDV6 would make a noticeable difference over the year.
My preferred option would be a TDV8 4.4, as they are returning an even better MPG than the TDV6, but alas the wallet say NO Sad
As far as the weight of your trailers go... yes you have me beat... but mine are partially liquid, and the C of G moves about depending on the terrain.... and as the liquid doesn't move in a linear direction, when you get the wobbles it can get really bad very quickly Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #375655 4th Mar 2016 8:09am
RiccartonRR
Rolling with laughter Rolling with laughter Them there constantly on the move loads are indeed tricky criters!! Rolling with laughter Rolling with laughter
I feel your pain - why does it almost feel worse when you stop and wait for the swaying to end Big Cry
My Luing bull weighed approx 1200kg and was too long to have a gate in the trailer so he wondered around constantly when being transported Big Cry When he came to the front of the trailer you were staring at the sky and when he moved to the back the horizon disappeared. I found that by braking he moved forward and levlled things out a tad Rolling with laughter Trailering 3000 litres of water in IBCs on the flat bed was a doddle by comparison Thumbs Up
T'was funny watching folks reactions when we were stopped at traffic lights - the towcar was stood still but the trailer was all over the place Rolling with laughter
IMHO there's nowt wrong with the TDV6 or the D3 that houses it. But - I'm daft enough to like the 2.2 TDCi so go figure. I believe that after the TD6 the TDV6 will be a revelation but if you ever try one I'll bet you covet the TDV8 (even if it a lowly 3.6).
Good luck with whatever you decide to buy (so long as it comes from the LR stable Thumbs Up ).
If you're ever close enough you're more than welcome to try your trailers behind my BAS 170'd Defender Back in a Defender!!
Post #375902 5th Mar 2016 9:49pm
miggit
Oh there is nothing like that sickening feeling (sea sick) when you stop at the lights and your load makes the car rock up and down... except possibly when you are trying to accelerate and the the whole shooting match is surging.... there ain't nothing like it Shocked
And your right a full IBC is a doddle, try one half full.... much more interesting Wink
Now if you were to squish your IBC so that it was 3 meters long, you'll get a better idea of what a loo is like Shocked + Sad + Mr. Green (but without the smile!)
I know that a TDV8 is the car that I want.... unfortunately the TD6 has eaten all the TDV8 funds, Censored , so I've got to take drastic action.... otherwise all the profit that I make will be used up trying to bailout my sinking ship Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #375932 6th Mar 2016 7:54am
miggit
UPDATE........201603.9.......
I had a call from the very very nice transmission specialist and it would appear to be sorted Very Happy , had a recon valve block installed and another flush and filter..... He recons that the new fluid that I put in dislodged a pocket of crap and this destroyed the valve block Sad That'll teach me to do nice things for the ffrr Evil or Very Mad All I have to do now is pick it up and test it.... I'll let you know later..... Now where's my block of wood and Rabbits' foot... Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #376498 9th Mar 2016 11:09am
