![]() | Home > Maintenance & Mods (L322) > paddle shifters in aluminium |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
I'm sure that someone will make an aluminium stick on bit now you have mentioned it!!! 2005 L322 Vogue Gold gone
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Looks like a fairly expensive add on. Over £330 for a set on the bay or £365 from Rimmer. I agree an aluminium paddle set would look great, but not sure if they would even fit.
En Vogue Member Since: 22 May 2014 Location: Munich Posts: 41 ![]() ![]() ![]() |
Hey guys, thanks for your replies!
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I'm not sure if you have the LR ones but here's a photo of the pre 2010 ones to assist if you don't:
Sorry for the late reply John, I have been quite busy, many thanks for the picture!!
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
They are now significantly cheaper here (still not "cheap" though) :
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3262 ![]() ![]() ![]() |
Plus import taxes for En Vogue? |
Hermes Member Since: 07 Nov 2020 Location: Oop north Posts: 108 ![]() ![]() ![]() |
Does anyone know where the ‘cheap plastic’ ones are available from? I need some for my 2010 SC
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Dan used to be the guy at Duckworth Landrover, a site sponsor. It's now Robin who sorts us out with 20% discount and free postage..
Thanks Haylands... I’ll give him a shout |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
You can get them from Powerful uk for about 40 quid |
Just picked up both the solid aluminium (with holes through the + and -) for £99 and the normal aluminium paddles for £30 as found on the L405 and Jaguar models in order to see if the mod is straight forward. Basically the paddles are almost the same as the L322 paddles, but the backing electronics trim that they fit to is not compatible, so you have to separate them and then fit them to the old L322 electronic switch trim to then fit to your wheel.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
From a previous post, maybe he can help us for the 2010-2012. I'd also be interested:
2015 Range Rover Autobiography 4.4 SDV8 |
