Home > Maintenance & Mods (L322) > paddle shifters in aluminium
En Vogue
Germany 2002 Range Rover Vogue Td6 Java Black
Hi everyone,
had a Jaguar XE for two weeks and the paddle shifters are IMHO exactly the same as in the MY 2012 L322.
But, paddles are offered in aluminium instead of cheap plastic like in the Range Rover. If I remember correctly, these aluminium coloured or red aluminium coloured paddles were also available for the L405 (?).
My question then is, since apparently they do look exactly the same, does anyone of you know if there is a possibility of fitting them?
Maybe the wiring is different but it would be nice to have them fitted.
Thanks in advance for your help guys.
Post #374452 26th Feb 2016 10:58pm
Roystonh
I'm sure that someone will make an aluminium stick on bit now you have mentioned it!!! 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #374503 27th Feb 2016 10:42am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Looks like a fairly expensive add on. Over £330 for a set on the bay or £365 from Rimmer. I agree an aluminium paddle set would look great, but not sure if they would even fit.
http://www.rimmerbros.co.uk/Item--i-T2R6547MMU Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #374504 27th Feb 2016 10:50am
En Vogue
Hey guys, thanks for your replies!
Indeed, prices for these paddle shifters are extremely high. There is a cheaper option, but probably it would not look as great as the ones provided by Jaguar/Land Rover.
http://www.ebay.co.uk/itm/2Pcs-Red-Paddle-...SwnH1WXCVB
http://www.ebay.de/itm/Schaltwippensatz-Ja...SwgQ9VlpyA
http://www.ebay.co.uk/itm/Genuine-Range-Ro...SwFMZWskA5
Without any knowledge regarding the wiring, replacing the cover shouldn't be that difficult right? I have been playing with the idea of ordering them and trying to make them fit, but if they end up being useless I would have thrown around 400 EUR out of the window.... Confused Confused
Post #374508 27th Feb 2016 11:42am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I'm not sure if you have the LR ones but here's a photo of the pre 2010 ones to assist if you don't:
regards
John
Post #374523 27th Feb 2016 1:11pm
En Vogue
Sorry for the late reply John, I have been quite busy, many thanks for the picture!!
One of the links I attached in the message above has a picture of the back of the paddles. The connectors seem a bit different, the newer ones do not have that blueish plug....let's see if I can figure something out the next weekend.
Still, thanks a lot for the picture. Will keep you posted.
Post #374970 29th Feb 2016 8:33pm
verydisco
They are now significantly cheaper here (still not "cheap" though) :
https://rimmerbros.com/Item--i-T2R6547MMU l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #578500 5th Jan 2021 10:37am
Weegie
Plus import taxes for En Vogue? Shocked John
GAP iiD BT
Post #578501 5th Jan 2021 10:45am
Hermes
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Does anyone know where the ‘cheap plastic’ ones are available from? I need some for my 2010 SC
I found another topic through the search function, which said they were £45 from someone called ‘Dan’ but didn’t give any other details about the company or who Dan is.
Anybody point m3 in the right direction?
Cheers
Post #578507 5th Jan 2021 11:54am
Hermes
Cheers
Post #578508 5th Jan 2021 11:55am
Dan used to be the guy at Duckworth Landrover, a site sponsor. It's now Robin who sorts us out with 20% discount and free postage..
Details here
https://www.fullfatrr.com/forum/duckworth-parts-vf24.html Pete
Post #578513 5th Jan 2021 12:26pm
Hermes
Thanks Haylands... I’ll give him a shout Thumbs Up
Post #578515 5th Jan 2021 12:45pm
wealy
You can get them from Powerful uk for about 40 quid
Post #621562 27th Jan 2022 2:38pm
Flashman
Just picked up both the solid aluminium (with holes through the + and -) for £99 and the normal aluminium paddles for £30 as found on the L405 and Jaguar models in order to see if the mod is straight forward. Basically the paddles are almost the same as the L322 paddles, but the backing electronics trim that they fit to is not compatible, so you have to separate them and then fit them to the old L322 electronic switch trim to then fit to your wheel.
After nearly pulling my hair out trying to remove the brass holding pins with pliers I found that if you just nudge the bottom of the brass pin up with a screwdriver or flat blade of a pen knife you can then push it further and out with a small pick tool. If you use pliers you will chew the weak brass pin to bits.
I then compared the old L322 black paddle with the new one and saw that the top loop for the brass pin is much wider than the old one and stops things lining up if you are retrofitting the new paddle to the old paddle electronics back plate.
I filled down the sides and the two small buttress mouldings and after a bit of trial and error the paddle fitted and the brass pin slid through and locked into place. I then fitted it to a spare wheel to see how it looks and voila!
When doing it make sure not to loose the springs as on the old paddles they are not glued in and can fly everywhere.
The solid aluminium ones have aluminium pin guides on the back so will need some dremel action, but I might give it a go in the future once I have tried these first.
An interesting mod, quite simple to get the parts as they are the same for LR and Jag, and often on the bay being sold as used. Tom
Current Drive
Previous Drives
Post #641816 2nd Sep 2022 5:12pm
garyRR
From a previous post, maybe he can help us for the 2010-2012. I'd also be interested:
TDV8_Tommy wrote:
Like this?
 2015 Range Rover Autobiography 4.4 SDV8
Post #641824 2nd Sep 2022 5:43pm
